Hatman777 Posted September 7, 2020 Share Posted September 7, 2020 Hello all, being new to the helix platform i had a concern with this weird repeating effect i get when using high gain, the higher the gain the more pronounced this effect is, im sure this is not supposed to be as such, in example i hit a power chord and then its like there is a really quick repeat after i've hit the chord, there is no reverb or any delay active Just OD , Amp and Cab, anyone ever experience this? and can maybe let me know what causes this ? Take A listen to the sample I recorded showing this Odd effect thanks all for the input Helix Issue 2.mp3 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 7, 2020 Share Posted September 7, 2020 Attach a copy (NOT a screenshot) of the preset so we can look at it. Quote Link to comment Share on other sites More sharing options...
Hatman777 Posted September 7, 2020 Author Share Posted September 7, 2020 Well I’m a helix noob so how would i save this preset And attach it not sure how to do that thanks I did check out all my settings they seem to be correct I thought that maybe it had something to do with the AES XLR cable to the Powercab plus so ran a 1/4 jack, still had the same effect what is odd is it does not happen on all presets just some that I have really high gain also noticed more predominant on fuzz type Pedals before the amp and cab thank you Quote Link to comment Share on other sites More sharing options...
Schmalle Posted September 7, 2020 Share Posted September 7, 2020 Do you use a high amount of early reflections (Relflec in cab parameters)? 1 Quote Link to comment Share on other sites More sharing options...
Hatman777 Posted September 7, 2020 Author Share Posted September 7, 2020 O Reflections Here is the complete preset i've been working on IOMMI HELL.hlx Thank you all for the help Quote Link to comment Share on other sites More sharing options...
Schmalle Posted September 7, 2020 Share Posted September 7, 2020 There is a Hall block active (DSP1) with short decay which would sound like an echo. 1 Quote Link to comment Share on other sites More sharing options...
Hatman777 Posted September 7, 2020 Author Share Posted September 7, 2020 Ahh yes I did Try with the Reverb block on and off still did the same thing ?? Quote Link to comment Share on other sites More sharing options...
Schmalle Posted September 7, 2020 Share Posted September 7, 2020 Also: The "OD" that you discribed in the op is not an overdrive, it's an octave fuzz. The weird thing you hear is the low octave that it mixes in. It doesn't track very fast. 1 Quote Link to comment Share on other sites More sharing options...
Hatman777 Posted September 7, 2020 Author Share Posted September 7, 2020 Yes this is true but does it with other OD or Distortion Pedals, So this is the weird thing I've figured out that it comes from the noise reduction decay settings, the higher the decay setting is the more pronounced this weird artifact effect is present so i lowered it to 5 ms and low and behold that artifact sound is practically gone this is very odd and strange but thanks for the input and feedback much appreciated Quote Link to comment Share on other sites More sharing options...
Dogaral Posted September 15, 2020 Share Posted September 15, 2020 Maybe, since what you uploaded sounds like it has 2 or 3 effects that cause delays and echos... could you please save a version of the patch without the octave fuzz, hall verb, and whatever else was diagnosed as a culprit by the helpful people in this thread, and upload it again? If, in fact, you can still hear the effect with the patch like that. cuz you said it happens without that stuff in there... so take the stuff out and try again. Cuz that's quite a bit of help you got already, which is free from a very cool user. Maybe that awesome person will help one last time if you send the dryest patch you got that still, to your ears, has some kind of echo going on. but from my experience (limited LoL), i think maybe it is from something else outside of your patch. like maybe you have something routed wrong? like i had mine connected to my computer with usb, and sound was coming out in real time and also like with a little echo, and it turns out it was the way i had the settings on the pc wiht driver delay or something. 1 Quote Link to comment Share on other sites More sharing options...
