Headphone Impedance
Darkdogeforce
I just bought a pod go and was looking at which headphones to buy. Looking at the FAQ it says the headphone impedance output is 63 ohms?? That can't possibly be right can it? The helix floor is 12 ohms. Why is the pod go more than 5 times higher? Using the rule of 8, that would mean you need to use headphones with over 500 ohm load with the entry level pod. Did the FAQ mean we should use headphones with over 63 ohms? I'm really confused.
It's a mistake which Frank Ritchotte of Line 6 checked with the technical team, and confirmed. It's 32 ohms not 63 so 32 ohm headphones are the best match.
  • Thanks 1
  • 1 year later...
