HX Stomp + Specular Tempus MIDI help
DionRushe
Hey guys! Abolutely loving 3.0 so far. I have a MIDI related question that hopefully somebody can help me with.
I am running my HX Stomp with a Specular Tempus and am having some problems getting it to communicate.
The tap tempo is working fine from the Stomp but is it possible to programme it to do this:
- Snapshot 1 in my stomp uses patch A in Tempus
- Snapshot 2 in my stomp also uses patch A in Tempus
- Snapshot 3 in my stomp switches to patch B in Tempus
I don't want to change bank on the tempus - I just want it to change to patch B from A when I hit footswitch 3 (snapshot 3) and vice versa. I seem to have tried everything including the new command center but can't seem to get it to work.
Is this doable?
Each patch in the Tempus should have a PC# associated with it. Assign that PC# to the Instant Command (IC1) in the snapshot you want to call it from:
IF
Patch A = PC#1
Patch B = PC#2
THEN
SS1/IC1=PC#1
SS2/IC1=PC#1
SS3/IC1=PC#2
If Global Settings>Preferences>Snapshot Edits is set to DISCARD, then don't forget to save the preset between each Snapshot Edit.
If set to RECALL then just save the preset when you're done.
  • 1 month later...
hi guys,
I have another question about using the Tempus with HX Stomp,
Is it possible to match the tempo of the both units just taping on the HX tap tempo switch?
I try to do that  by setting the IC1 of my snapshot  to CC25 to the Tempus, with no setting for the speed, but I couldn't get the tempo changing after taping on the HX FS3.
Did I miss something?
Thanks for any help.
  • 5 months later...
Sorry to necro this thread, but I just got a Stomp and am trying to configure it to control my tempus. I don't understand the first reply. When I look in Command Center, I only seem to pick between MC and CC as midi options. Within the CC options, I don't see any options for PC.
Also, since there are a limited number of IC's in Command Center, is it possible to just call up a preset on the Tempus that already has all the parameters you want saved instead of sending multiple CC messages to configure what you want each time?
Thanks for your help.
I assume that's what a SAVED preset on the tempus is, all settings saved in one place.
So if I understand you correctly, in Command Center, my first IC would be set to Bank/Program, and I would set the "Program" number to the preset number on my Tempus, and then use a second IC to select Channel A or B using the correct CC message?
Example: Tempus Preset 10A would look like
IC1: Bank/Program > MIDI Channel 15 > Program 10 (all other parameters left off)
IC2: MIDI CC > MIDI Channel 15 > CC#18 > Value (Any)
There is no Channel A/B.
From Page 2 of the manual:
Preset System
Specular Tempus has 32 presets organized within 4 pages, where each page contains 4 banks, and each bank contains 2
patches (A and B).
That's only relevant if you are NOT using a MIDI Controller.
When using a MIDI Controller, you call the 32 presets directly using MIDI PC#s 0-31.
Refer to page 18 of the manual.
Bank 1 Patch A = PC#0
Bank 1 Patch B = PC#1
Bank 2 Patch A = PC#2
Bank 2 Patch B = PC#3
etc,
Bank 16 Patch A = PC#30
Bank 16 Patch B = PC#31
So, all you have to do is set Snapshot 1 (the default Snapshot that loads with the preset) IC#1  to the PC# you wish to load on the Tempus when the HXS preset loads.
You can use the same IC#1 to load a different Tempus preset in Snapshots 2 and 3 if you so desire.
