Can you split A/B exclusively?
tcamuso
Is there any way to have an exclusive A or B?
I can assign a foot switch to the A/B split and get 100% B, but when I toggle the foot switch to bypass the split, I get B merged with A, when what I want is 100% A.
So, I want an A/B split that gives me 100% A and 0% B, or 0% A and 100% B.
In truthtable terms:
Footswitch State      :   OFF      ON
Output from split A/B :  A only    B only
                         No merge  100%
2 hours ago, SaschaFranck said:
You don't need to control the bypass status of the switch (I really wish it was that easy, would allow for some more trickery, too) but the value of the slider.
Take a look:
No joy. I can get A-only, but when I flip the switch, I still get an A/B merge.
18 minutes ago, themetallikid said:
Yes, I do this with my multi amp presets when using snapshots for clean/dirty tones.  I just have the slider for a/b % set to 100% either direction and attached for that snapshot.  I'm sure you can attach a min/max setting as well so that they are a100 or b100.
Doesn't work for me.
I don't know what I'm doing wrong, but I cannot select an exclusive A path or exclusive B path with one switch.
If the footswitch makes one exclusive, flipping the switch ALWAYS gives me a merge of both.
When you use "Route to" as a target, the control assigns automatically come up as in the picture I posted. So it's not *that* much of an effort (yet, doing it via bypass straight on the split would be great as I could then exclude it from snapshot bypass - which isn't possible this way).
OK, gang, I finally got it to work using saschafrank's suggestion to route the A/B split to a switch and set the max/min.
I did this in the Helix Editor, and it took a few cycles of the assigned footswitch before it actually did anything, but now it's working.
I don't know why the switch did not immediately respond to the configuration in the Helix Editor, but it seems to be working as expected now.\
2 minutes ago, SaschaFranck said:
Guess you'd have to update your Helix - as I'm sure that's what rd2rk already did.
Being intimately familiar with software updates, I'm gonna wait a bit before I commit.
I will be looking forward to seeing what those new models are in that patch, though!
Never had backwards compatibility problems as long as it's not a missing model issue, next time you reboot it just optimizes for the newer FW.
Anyhow, the preset is just what Sascha suggested, which you now have working.
All good!
Oh really? So in case I create a patch with 3.0 using just older models, that patch would be compatible with older FW versions? I thought that was different and the patch was kinda "tagged", so it'd only load in FW versions as new or newer.
I'm basing that on having restored setlists created with previous versions after an update. They always worked fine, then rebuilt after a reboot.
Sure, that's the normal way. But I was thinking whether it'd work the other way around. As in patches (or setlists) created in, say, FW3.x and then loading them in FW2.x.
I thought that way it wouldn't work.
