Pacemaker1000 Posted December 11, 2020 Share Posted December 11, 2020 Is it possible to pair a transmitter with 2 receivers. That is one in the Spider V60 and a stand-alone one for another amp? So theoretically you can play both amps simultaneously? ps if you’re reading this and know about the usb failure what is the best fix as I’ve seen many cheers Quote Link to comment Share on other sites More sharing options...
OmniFace Posted January 19, 2021 Share Posted January 19, 2021 No. With a traditional wireless radio it might work because it's just radio waves. But these are digital and two competing signals sending 0s and 1s will just cause interference and the receiver won't be able to convert those 0s and 1s into usable audio. Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 20, 2021 Share Posted January 20, 2021 On 12/11/2020 at 2:39 PM, Pacemaker1000 said: Is it possible to pair a transmitter with 2 receivers. That is one in the Spider V60 and a stand-alone one for another amp? So theoretically you can play both amps simultaneously? ps if you’re reading this and know about the usb failure what is the best fix as I’ve seen many cheers Yes, if you have a single transmitter and have both receivers set to the same channel, they'll both receive the signal. Quote Link to comment Share on other sites More sharing options...
