LongDuckDong Posted January 8, 2021 Share Posted January 8, 2021 I just bought the HD Pro X and am trying to figure it out. It seems as though all of the amp sounds are muffled (e.g. lacking brightness). How can I get a more bright/crisper sound? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted January 8, 2021 Share Posted January 8, 2021 Too much BASS and little PRESENCE in the default amp models settings. (and often too much DRIVE) Fortunately, dedicated amp controls are at disposal, easy fix. The output mode is also important, make sure it is set to Studio/Direct. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips 1 Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted January 8, 2021 Share Posted January 8, 2021 if you use one output, it is quite possible a phase issue 1 Quote Link to comment Share on other sites More sharing options...
LongDuckDong Posted January 8, 2021 Author Share Posted January 8, 2021 3 hours ago, hurghanico said: Too much BASS and little PRESENCE in the default amp models settings. (and often too much DRIVE) Fortunately, dedicated amp controls are at disposal, easy fix. The output mode is also important, make sure it is set to Studio/Direct. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips The output mode was the culprit. Thank you, sir. Quote Link to comment Share on other sites More sharing options...
LongDuckDong Posted January 8, 2021 Author Share Posted January 8, 2021 2 hours ago, pianoguyy said: if you use one output, it is quite possible a phase issue It was the output default eq settings for bass, focus, and hi. Thank you, sir. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted January 9, 2021 Share Posted January 9, 2021 Do you have it set to Studio Direct output ? Quote Link to comment Share on other sites More sharing options...
LongDuckDong Posted January 9, 2021 Author Share Posted January 9, 2021 8 hours ago, joel_brown said: Do you have it set to Studio Direct output ? I didn't at the time of posting. I do now. Thank you for your help. Quote Link to comment Share on other sites More sharing options...
LongDuckDong Posted January 11, 2021 Author Share Posted January 11, 2021 On 1/8/2021 at 2:07 PM, hurghanico said: Too much BASS and little PRESENCE in the default amp models settings. (and often too much DRIVE) Fortunately, dedicated amp controls are at disposal, easy fix. The output mode is also important, make sure it is set to Studio/Direct. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Your suggestion helped, but I still have the muffled sound. In fact all of the amps/cabs sound similar. My Spider Jam has the sound I like (Mesa Boogie Dual Rectifier) which is nice and bright. This is weird because the Pro X has the M/B Dual Rectifier, as well, but it sounds so much different (muffled) from the Spider Jam's sound (bright). Quote Link to comment Share on other sites More sharing options...
hurghanico Posted January 11, 2021 Share Posted January 11, 2021 35 minutes ago, LongDuckDong said: Your suggestion helped, but I still have the muffled sound. In fact all of the amps/cabs sound similar. My Spider Jam has the sound I like (Mesa Boogie Dual Rectifier) which is nice and bright. This is weird because the Pro X has the M/B Dual Rectifier, as well, but it sounds so much different (muffled) from the Spider Jam's sound (bright). Your Spider Jam has a speaker and that speaker affects all the sounds you get from that amp. The HD Pro X has its own cab/speaker/mic models and each of them has its own sound which represents not less than 50% of the modeled amp sound. Ideally you shouldn't send the modeled speaker signal into a real speaker for guitar, the modeled speaker signal should go instead into a flat response monitor, otherwise the result will be undoubtedly muffled because guitar speakers (real or modeled) are like heavy filters (flat response monitor are not) and sending an alteady filtered signal into another filter is too much in most cases. So if you are connecting the POD to a guitar amp it would be better to disable the modeled cab, or if you are instead connecting the POD to a flat response monitor or headphones you should try different mics and/or cabs models given that each of them change a lot the result. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
LongDuckDong Posted January 12, 2021 Author Share Posted January 12, 2021 23 hours ago, hurghanico said: Your Spider Jam has a speaker and that speaker affects all the sounds you get from that amp. The HD Pro X has its own cab/speaker/mic models and each of them has its own sound which represents not less than 50% of the modeled amp sound. Ideally you shouldn't send the modeled speaker signal into a real speaker for guitar, the modeled speaker signal should go instead into a flat response monitor, otherwise the result will be undoubtedly muffled because guitar speakers (real or modeled) are like heavy filters (flat response monitor are not) and sending an alteady filtered signal into another filter is too much in most cases. So if you are connecting the POD to a guitar amp it would be better to disable the modeled cab, or if you are instead connecting the POD to a flat response monitor or headphones you should try different mics and/or cabs models given that each of them change a lot the result. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips I hooked the Pro X up tomy studio monitors, wow, what a difference it makes. Thanks. Quote Link to comment Share on other sites More sharing options...
