Jimmybeijng2014 Posted February 5, 2021 Share Posted February 5, 2021 For some reason I think the hd500x driver mess up with my external audio interface driver,but when i connect hd500x with a usb cable,it automaticly connecting to the driver right ? as long as a usb cable is connecting,it force the signal routing to the usb,but I just want to edit the parameters with the hd500x editor for the sake of making life easier,why should I must install the lollipoping out of date driver ?Is there a workaround ?I don't really understand the design,for what?By the way,the driver crashes my windows 10!!!Why don't line 6 just fix their lollipop? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 5, 2021 Share Posted February 5, 2021 The answer to the question in your title is ‘No’. As for the rest of your comments I would open a support ticket. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted February 6, 2021 Share Posted February 6, 2021 Well, you can use the editor... in offline mode. This means without the unit connected. Quote Link to comment Share on other sites More sharing options...
Jimmybeijng2014 Posted February 6, 2021 Author Share Posted February 6, 2021 Thanks for the reply,it's really annoying,when I change the block placement in the signal chain via hd500x editor,it crash my pc,wether I use my external audio card as default or the unit's,latest windows 10 version,it's really frustrating.I tried different USB ports on my motherboard,no luck,I don't know what to do,I end up uninstalling everything related to line 6 and it's also a pita. Quote Link to comment Share on other sites More sharing options...
Jimmybeijng2014 Posted February 6, 2021 Author Share Posted February 6, 2021 13 hours ago, pianoguyy said: Well, you can use the editor... in offline mode. This means without the unit connected. What's the point to do so if i can't hear anything through my unit? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 6, 2021 Share Posted February 6, 2021 You’re right. There’s no point given what you are trying to do. I think pianoguy was just clarifying, correctly, that my earlier response was technically inaccurate. You can, in fact, use the edit program without the driver - which was your question. It just doesn’t do you any good. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted February 6, 2021 Share Posted February 6, 2021 For example, we have a lot of people who sell their units but want be able to view patches for so that they can do the same settings on a different device. I didn't say it would help solve your issue. I was just stating that, yes, the editor does work without a unit connected - ie, the driver. 1 Quote Link to comment Share on other sites More sharing options...
DolurumMafikala Posted February 7, 2021 Share Posted February 7, 2021 20 hours ago, Jimmybeijng2014 said: Thanks for the reply,it's really annoying,when I change the block placement in the signal chain via hd500x editor,it crash my pc,wether I use my external audio card as default or the unit's,latest windows 10 version,it's really frustrating.I tried different USB ports on my motherboard,no luck,I don't know what to do,I end up uninstalling everything related to line 6 and it's also a pita. I would try to isolate what is causing the problem. Make sure that Windows and your audio software (e.g. DAW) are not using the Pod as an audio device, whether by default or not. For example, don't even run your DAW. Just have HD Edit running and nothing else. You would need to listen directly to the Pod via headphones, your amp or some speakers. Does the problem still occur in those circumstances? Depending on the answer you now know whether you are having a problem with the streaming audio or with the control connection and can focus your efforts to remove the problem. Quote Link to comment Share on other sites More sharing options...
Jimmybeijng2014 Posted February 7, 2021 Author Share Posted February 7, 2021 Thanks guys,I think Line 6 should pay you folks for the support Quote Link to comment Share on other sites More sharing options...
