mike_richardson Posted April 3, 2021 Share Posted April 3, 2021 My HX Stomp does just about anything I could ask. However, I would really like to be able to use one of the TRS insert jacks as a dual tip-to-ground switch. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 3, 2021 Share Posted April 3, 2021 Not sure what you mean. Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 3, 2021 Share Posted April 3, 2021 5 hours ago, mike_richardson said: However, I would really like to be able to use one of the TRS insert jacks as a dual tip-to-ground switch. Uh? What? Which? Where? Baffled! Quote Link to comment Share on other sites More sharing options...
soundog Posted April 3, 2021 Share Posted April 3, 2021 ....so, sometimes a device will have a 1/4" connection that can act as a switch by grounding "tip to ground". The answer to your query is "no." The jacks are for audio only and can't be used for switching. (At least I think that is what you are asking..) 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 3, 2021 Share Posted April 3, 2021 2 hours ago, soundog said: ....so, sometimes a device will have a 1/4" connection that can act as a switch by grounding "tip to ground". The answer to your query is "no." The jacks are for audio only and can't be used for switching. (At least I think that is what you are asking..) Except for the rear jack labelled "FS 4/5. 1 Quote Link to comment Share on other sites More sharing options...
soundog Posted April 4, 2021 Share Posted April 4, 2021 Har! I've got mine plugged up with switches, so forgot about those! Now that you mention it, maybe that's what the OP is referring to. If so @mike_richardson, you can go from the FS 4/5 jack (which is for audio) to 2 TS tip-to-ground switches. I use two toggle push-button switches there with LEDs (you have to set the switches to "momentary" in the Stomp) and sync the lights to on and off. Works great. But, again, the send/return loops are for audio only. 1 Quote Link to comment Share on other sites More sharing options...
mike_richardson Posted April 7, 2021 Author Share Posted April 7, 2021 Thanks! Got the answer I needed! 1 Quote Link to comment Share on other sites More sharing options...
