bhecklick Posted April 22, 2021 Share Posted April 22, 2021 Hey all - New to the forums and new to the direct-to-speaker world. I have a PODHD500 and an EV powered speaker. The POD was used but the speaker is brand new. The speaker works just fine to stream Bluetooth music but I can’t get any audio from the POD. I plugged my guitar into the guitar in 1/4” input, plugged my XLR into the balanced left output and the other end of the XLR into the speaker. Nothing. Unfortunately I don’t have another 1/4” cable to see if that works but I’m wondering if I’m just an idiot and did something wrong? Thanks! Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted April 22, 2021 Share Posted April 22, 2021 Does the Pod work if, as example, you use headphones? There are so many options with the Pod, we need to know it is working or if it is a setting. Did you try the XLR from the right output? Left didn't work. But that is what stereo is all about. Does the speaker work using the 1/4" direct from the guitar? Remember - the Master Volume (on the Pod) matters. Everything else is patch related, but the MV is global. Quote Link to comment Share on other sites More sharing options...
spaceatl Posted April 22, 2021 Share Posted April 22, 2021 The XLR out on the POD is actually mic level and this can be a problem with some monitors...Usually means weak signal..Try a 1/4 cable from one of the Main outs. That will also sum the output mono... Quote Link to comment Share on other sites More sharing options...
hurghanico Posted April 22, 2021 Share Posted April 22, 2021 As already suggested your monitor expects a Line level signal but the POD XLR can give only a Mic level signal. If your monitor has a LINE/MIC switch it should be set to MIC if you connect the POD XLR, otherwise the only solution is to connect a standard jack and set the 1/4" OUT switch near the pedal to LINE. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
