helix lt, powercab 112+, and DT25 using l6link
PaulTBaker
I have been using a helix lt and dt25 connected by the l6link.  Just bought a PC112+.  can I connect that to the dt25 using l6link?  If not, what is the best way to connect these three so I can get stereo?
Also, I have been reading where the pc112+ input light needs to be yellow for optimal input.  I know I can boost the input using the helix on each patch (under the settings for the powercab), but is there a global setting for the powercab so i don't have to change each patch (preset)?
thanks.
You can connect two Powercabs or two DT amps via L6 Link, but you can’t connect one of each. It’s just a limitation on how L6 Link is implemented on the Helix.
You could connect the Powercab via L6 Link and then use a 1/4” cable to send audio to the DT-25 and control it via MIDI. Or you could do the opposite... I guess it just depends on what you want to do.
