z3albw1rr Posted May 7, 2021 Share Posted May 7, 2021 3.11 Firmware, 3.10 Edit version. Should all be the latest. I watched this video (below) where he sets up the Up/Down buttons to be "HX Snapshot" buttons. I can't seem to do that. On both the computer and on the unit it shows when you select these, some additional options like choosing the LED color and "customize". He said he had it in "8 Snaphots" but I'm wondering if there's some global behavior I'm not seeing. I can absolutely go into Command Center and set any of the "middle 8" switches to be a Snapshot button. But he's clearly using the up/down (farthest left switches, 1 and 7 I guess) switches as Snapshot switches. Command Center allows me to assign them that way, but, they don't behave as his does. I thought I was missing a global setting, but, since the "customize" icon and LED controls are missing in the software and on the device, I'm not sure that's it. The video's a year old - did they remove this function? I could understand if it was a glitch in the Mac version of the software, but not on the device itself. See at 5:11. When he clicks Snapshot at 5:18 you'll see 5 rows - I only have the first 3 - no LED or Customize. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 7, 2021 Share Posted May 7, 2021 Global Settings>Footswitches>Up/Down Switches (5th knob from left) Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 7, 2021 Share Posted May 7, 2021 You need to have the Stomp Footswitches setting under Global Settings>Footswitches set to 10 Stomps. This is only available on the Floor and the Rack, not the LT. Quote Link to comment Share on other sites More sharing options...
z3albw1rr Posted May 9, 2021 Author Share Posted May 9, 2021 On 5/6/2021 at 11:34 PM, phil_m said: You need to have the Stomp Footswitches setting under Global Settings>Footswitches set to 10 Stomps. This is only available on the Floor and the Rack, not the LT. Ahh, OK. Bummer it's not on the LT. Quote Link to comment Share on other sites More sharing options...
