johnsetej Posted July 29, 2021 Share Posted July 29, 2021 Hello All, I picked up a JTV69 today and love it. I've been using it with a pod hd500x and it really works works well together. There is a really odd issue I am having with it. The variax hardware works well out of the VDI output as do the magnetic pickups, but out of the 1/4" output the variax hardware is extremely faint. I can here it but its barely there. The magnetic pickups work fine out of the 1/4" output. I updated firmware incase there was some sort of corruption but it didn't solve the issue. Has anyone else had this issue and been able to solve it? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted July 29, 2021 Share Posted July 29, 2021 Using 1/4" output,... 1) Use a TRS (tip/ring/sleeve) 1/4" plug. Tip= signal, ring= battery +V voltage, sleeve= ground return. 2) Make certain there's a fully charged battery in the battery compartment. Quote Link to comment Share on other sites More sharing options...
johnsetej Posted July 29, 2021 Author Share Posted July 29, 2021 2 hours ago, psarkissian said: Using 1/4" output,... 1) Use a TRS (tip/ring/sleeve) 1/4" plug. Tip= signal, ring= battery +V voltage, sleeve= ground return. 2) Make certain there's a fully charged battery in the battery compartment. I'm sorry, I don't understand what you are trying to tell me? Are you saying I need to use a TRS cable for the 1/4" output? What is the purpose of using a TRS over a standard mono 1/4" cable on a JTV69? Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 29, 2021 Share Posted July 29, 2021 There are three ways to provide power to a Variax guitar’s modeling electronics: 1) A VDI cable connected to a compatible Line 6 device. You mention that this method is working for you. 2) A standard TS mono guitar cable in the 1/4” output along with a charged battery in the Variax guitar. 3) An external Variax power supply. In this case you need to use a TRS cable in the 1/4” output. The ‘R (ring)’ contact supplies the power to the guitar. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted July 29, 2021 Share Posted July 29, 2021 Best performance is with a TRS cable,... and what sliverhead said. TRS has been part of the world of guitars with active powered electronics, going back to the mid 1970's. Quote Link to comment Share on other sites More sharing options...
johnsetej Posted July 29, 2021 Author Share Posted July 29, 2021 Ok that makes a bit more sense. I did have some external psu when I had first gen variax, but sold the supply with the guitars. Ill see ifi can borough one to test the guitar, but the goal is to be able to use it wireless for some stuff and a psu would defeat that purpose. For most of my use I'll be using the pod hd500x. Quote Link to comment Share on other sites More sharing options...
johnsetej Posted July 30, 2021 Author Share Posted July 30, 2021 Thanks to everyone who responded, the issues does seem to be in the guitar. I'll be dropping it off to a tech in the next couple of days to see if they can sort it out. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted July 30, 2021 Share Posted July 30, 2021 Best to go to an authorized service tech, as they will be more experienced with this guitar. https://line6.com/find/service_center/ Quote Link to comment Share on other sites More sharing options...
johnsetej Posted July 30, 2021 Author Share Posted July 30, 2021 4 minutes ago, psarkissian said: Best to go to an authorized service tech, as they will be more experienced with this guitar. https://line6.com/find/service_center/ Definitely!! One is close by and I've had other things serviced with them in the past. Looking forward to getting this sorted out. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted July 30, 2021 Share Posted July 30, 2021 :) Quote Link to comment Share on other sites More sharing options...
