PierM Posted September 2, 2021 Share Posted September 2, 2021 So, I wanted to give this new version a try, and grabbed one. Firmware is the latest. For the test I'm using my old G10 Receiver/Charger. To avoid any Standby charge leaking, I did a single test, no standby pause; Full Charge, Full Discharge. To do so I plugged the G10TII straight out of my Plus Pedal signal SEND, to feed a continuous signal into it, and prevent the auto-standby. Charging (Red Flashing) started at 10:40 (first charge ever, out of the box) Charging (Solid Green) completed at 12:18 (kept in the charger ~20 extra minutes just to be sure cycle was completed) Play/Duration Test started at 12:36 Play/Red Flashing started at 18:32 Play/Battery died at: 18:49 Battery Charge Duration (Continuous Play); 6hrs, 13min Package Front/Back; Charge Started at 10:40 Charge Completed at 12:18 Playing Test Started at 12:36 Red Flashing started at 18:32 Battery died at 18:49 I will play with it couple of cycles more, then I'll redo the test, to see if there is some improvement. Still, 6 hours is better than 2.5 I was getting with the other G10, after the fire hazard firmware... You can be sure, dear L6; I won't install any new firmware on this thing, ever! Quote Link to comment Share on other sites More sharing options...
PierM Posted September 6, 2021 Author Share Posted September 6, 2021 update; Second cycle lasted a bit more; 6hrs and 30min. Quote Link to comment Share on other sites More sharing options...
ziomalkamil Posted October 4, 2021 Share Posted October 4, 2021 Does the Line6 G10S comes with new GII transmiter? @PierMHow is battery life at the momment? Quote Link to comment Share on other sites More sharing options...
PierM Posted October 4, 2021 Author Share Posted October 4, 2021 2 hours ago, ziomalkamil said: Does the Line6 G10S comes with new GII transmiter? @PierMHow is battery life at the momment? Yes, all new stocks of G10 are with the TII, and it's usually specified in the product AD specs. Previous version is gone. Battery life is still around 6.5hrs after a month, so I believe this is the max possible duration for my environment (there it can be a slight difference between cold and warm environments). Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted October 4, 2021 Share Posted October 4, 2021 2 hours ago, PierM said: Yes, all new stocks of G10 are with the TII, and it's usually specified in the product AD specs. Previous version is gone. Battery life is still around 6.5hrs after a month, so I believe this is the max possible duration for my environment (there it can be a slight difference between cold and warm environments). Well it's nice that they seem to have addressed the issue...still a little annoyed that I'll have to drop another $100 to get back the device I originally purchased. Oh well... life goes on. 1 Quote Link to comment Share on other sites More sharing options...
paulkers2018 Posted December 30, 2021 Share Posted December 30, 2021 I just received my G10T II today, after a 2 month waiting period, my question is do I need to purchase a G10S receiver/charger unit? I purchased it from Guitar Center w/Spider V 120MKII amp, they never told me about what additional equipment I might need? Any help would be appreciated. Is there software I should download for these products? Thanks, L8R Paul Kershner paulkers2018@gmail.com Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 31, 2021 Share Posted December 31, 2021 46 minutes ago, paulkers2018 said: I just received my G10T II today, after a 2 month waiting period, my question is do I need to purchase a G10S receiver/charger unit? I purchased it from Guitar Center w/Spider V 120MKII amp, they never told me about what additional equipment I might need? Any help would be appreciated. Is there software I should download for these products? Thanks, L8R Paul Kershner paulkers2018@gmail.com You don’t need any additional equipment. The receiver is built into the amp, and you charge the transmitter by plugging it into the amp’s guitar input. Quote Link to comment Share on other sites More sharing options...
