baltodoc1 Posted September 8, 2021 Share Posted September 8, 2021 I just bought a used Line 6 Helix LT for my bass. How do I switch from guitar to bass? Please help. Quote Link to comment Share on other sites More sharing options...
waymda Posted September 9, 2021 Share Posted September 9, 2021 What do you mean? You plug in the bass and then use the models you want to create a patch - not sure what else there is to know. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 9, 2021 Share Posted September 9, 2021 What @waymda said. You might also want to reconsider what you're using as a playback system. Running your bass into a guitar amp/cab won't work nearly as well as using a proper bass amp. OTOH, a decent quality 12" FRFR powered cab can work well for both guitar and bass. 1 Quote Link to comment Share on other sites More sharing options...
codamedia Posted September 9, 2021 Share Posted September 9, 2021 15 hours ago, baltodoc1 said: I just bought a used Line 6 Helix LT for my bass. How do I switch from guitar to bass? There are BASS AMPS and BASS EFFECTS already available in the Helix The effects are all lumped together, not in separate sub categories. You need to know which specific effects were made for BASS (the manual/model list will tell you) BASS AMPS are in a separate sub category Choose Amps or Preamps or Amp/Cabs Then Choose "Bass" The models will appear Keep in mind you are not limited to the Bass Amps and Bass effects.... you can use anything you want. 1 Quote Link to comment Share on other sites More sharing options...
