briandshelby Posted March 5, 2014 Share Posted March 5, 2014 Hi all, I love that thick sounds you get from double tracking with really tight playing. BUT, I'm recording a tough rhythm section and having difficulty playing multiple takes that line up well. I know - I need to practice. In the meantime, does anyone have suggestions for how to set up a chorus effect so that my left and right channels would sound close but distinct? Any ideas for which chorus and settings? Maybe split the signal path after the amp and have a very light chorus in only one side and pan the two paths? A quick search here didn't show anything useful. Going direct out with S/PDIF to an interface, if that matters. Thanks - Brian Quote Link to comment Share on other sites More sharing options...
brian6string Posted March 5, 2014 Share Posted March 5, 2014 ...or...Setup a dual amp patch, with both sides having the same amp/cab, and put a short (20-40ms) digital delay 100% wet on one side only, before the amp. 100% wet will result in only the delayed sound going thru. Pan each side a little bit left and right to taste. 2 Quote Link to comment Share on other sites More sharing options...
radatats Posted March 5, 2014 Share Posted March 5, 2014 with a single amp patch, place a digital delay set at 20-34 ms, 100% mix, in path A, nothing path B and you will get that double track effect... keep mixer panned left and right... Quote Link to comment Share on other sites More sharing options...
radatats Posted March 5, 2014 Share Posted March 5, 2014 I used the above solution a couple of times, but I stopped using it because although it gives a more tridimensional effect it seems to me that doing so I get more artifacts in the final sound.. so putting it in the post section at 50% mix gives you the same thing but with better results? I will check it out... thanks! Quote Link to comment Share on other sites More sharing options...
duncann Posted March 5, 2014 Share Posted March 5, 2014 Another option is to use a pitch glide at 100% mix and +.1 pitch instead of a delay. Adjust the mixer pan controls appropriately.This will give a chorus type effect so you may or may not like it. Quote Link to comment Share on other sites More sharing options...
briandshelby Posted March 6, 2014 Author Share Posted March 6, 2014 Thanks for the ideas, excited to try them later today. Anyone tried a pitch shifter and a delay to get a little detune and time separation? Quote Link to comment Share on other sites More sharing options...
NucleusX Posted March 7, 2014 Share Posted March 7, 2014 Does the POD not have a detuner ? that was going to be my suggestion. I found using a detuner to be the best solution. Well... at least with my other gear it is. Quote Link to comment Share on other sites More sharing options...
duncann Posted March 7, 2014 Share Posted March 7, 2014 I guess a detuner would be the pitch glide. Quote Link to comment Share on other sites More sharing options...
