denyrunner Posted October 29, 2021 Share Posted October 29, 2021 Saw an ad for the Ampero Press Passive Volume / Expression Pedal. Has anyone tested this with hx stomp's expression 1/2 input? Wondering if it works well and as-well as Mission? Quote Link to comment Share on other sites More sharing options...
piepolitb Posted November 11, 2021 Share Posted November 11, 2021 Hi, I have the Hotone, very nice pedal but I can't make it work properly: I have 2 exp pedal un a Y cable (TRS --> TS + TS): the boss exp pedal works great after some tweaking on the settings. The hotone don't: it gets to 100 in toe position, 0 to middle and it sweeps back to 100 in heel position. Any ideas ? I'm living with that issue thanks to a very badly DIY workaround: a placed a cable under the heel position so that I can't go further than middle position :D Quote Link to comment Share on other sites More sharing options...
jcoops Posted July 28, 2022 Share Posted July 28, 2022 On 11/12/2021 at 12:09 AM, piepolitb said: Hi, I have the Hotone, very nice pedal but I can't make it work properly: I have 2 exp pedal un a Y cable (TRS --> TS + TS): the boss exp pedal works great after some tweaking on the settings. The hotone don't: it gets to 100 in toe position, 0 to middle and it sweeps back to 100 in heel position. Any ideas ? I'm living with that issue thanks to a very badly DIY workaround: a placed a cable under the heel position so that I can't go further than middle position :D Have you changed the global settings yet and does it work? I am thinking of getting this pedal Quote Link to comment Share on other sites More sharing options...
datacommando Posted July 30, 2022 Share Posted July 30, 2022 On 7/28/2022 at 7:32 AM, jcoops said: Have you changed the global settings yet and does it work? I am thinking of getting this pedal There really should be a “sticky” thread for this thing about expression pedals and Line 6 hardware. Check the date on these threads. https://line6.com/support/topic/15999-external-expression-pedal-calibration/ Hope this helps/makes sense.j Quote Link to comment Share on other sites More sharing options...
duc1000 Posted December 28, 2023 Share Posted December 28, 2023 Did you find a solution @piepolitb? I have the same issue with my Hotone Ampero Press. Thx Quote Link to comment Share on other sites More sharing options...
oscardrbcn Posted January 4 Share Posted January 4 (edited) On 12/28/2023 at 3:49 PM, duc1000 said: Did you find a solution @piepolitb? I have the same issue with my Hotone Ampero Press. Thx Hi, I had the same problem with the new Hotone Ampero Press 2. The solution is to use a TRS cable (stero cable with two black rings). I tried a Y cable with 1 TRS and 2 TR to use the button but it doesn't work, the expression pedal goes 0-100 (middle)-0 The problem with this is that I can not use the foot switch. Edited January 6 by oscardrbcn Adding more information Quote Link to comment Share on other sites More sharing options...
guig53 Posted January 11 Share Posted January 11 No solution for AMPERO II PRESS with HX effects.. :( It's a shame cause it's light compared to the Mission pedal. Quote Link to comment Share on other sites More sharing options...
oscardrbcn Posted January 12 Share Posted January 12 On 1/11/2024 at 1:12 PM, guig53 said: No solution for AMPERO II PRESS with HX effects.. :( It's a shame cause it's light compared to the Mission pedal. Why? I think it has to work with a TRS cable. In HX Stomp works Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted January 12 Share Posted January 12 I found IME that the "expression" pedel in Hx/Helix is just looking for a simple resistance sweep as a volume pedal does. One side of a volume pot to ground. Anything labled "expression" doesnt not seem to work. Quote Link to comment Share on other sites More sharing options...
