aed1421 Posted October 31, 2021 Share Posted October 31, 2021 I am trying to edit one of my patches and I have a block I can't delete or replace with something else. I can add to the block but I can't delete it completely and add the new effect. When I try to delete it the scribble script goes blank but the effect is still there and I can turn it on and off. Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 31, 2021 Share Posted October 31, 2021 Please describe in detail how you are attempting to delete it. What specific action(s) are you doing? Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted November 4, 2021 Share Posted November 4, 2021 On 10/31/2021 at 11:46 AM, aed1421 said: I am trying to edit one of my patches and I have a block I can't delete or replace with something else. I can add to the block but I can't delete it completely and add the new effect. When I try to delete it the scribble script goes blank but the effect is still there and I can turn it on and off. You don't really delete a block on HX devices, you either clear them by selecting 'None' from the menu or alternately by selecting 'Clear Block' from the 'Action' menu, or you can replace the block contents with another effect, amp, etc.. Are you saving after your modification? If the process you are using works on your other presets I would just assume the preset is corrupt and copy a new/blank one over on top of it. If this is not the case and the problem is procedural you should provide details, as Silverhead requested, as to exactly how you are going about clearing or editing the block and what you expect to see when you are done. Does this occur on the device and/or in HX Edit? If it only happens on the device is it possible that for example the click function on your joystick is not functioning? If this is indeed a recurring problem, did you do the global reset and reload of your backup after you last upgraded your firmware. If not, do that, or even consider running through the entire firmware update process again, making sure to do the global reset and backup. Quote Link to comment Share on other sites More sharing options...
