magsterone Posted November 30, 2021 Share Posted November 30, 2021 Anyone else having issues loading workbench with OS Monterey? Bought new iMac and workbench and updater will not load due to incompatibility with Monterey. Any news on updates? Thanks and be safe. Joe in Mobile Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 30, 2021 Share Posted November 30, 2021 For which Variax ? Quote Link to comment Share on other sites More sharing options...
magsterone Posted November 30, 2021 Author Share Posted November 30, 2021 Shuriken, the workbench program is not allowed to load due to not being compatible with Monterey. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 30, 2021 Share Posted November 30, 2021 Shuriken uses Workbench HD. No Monterey yet. Compatibility notices at top of the page. Quote Link to comment Share on other sites More sharing options...
vavaha Posted December 25, 2021 Share Posted December 25, 2021 and i have the problem too. not work with monterey((((( when will they provide support? this is very sad! the new $ 2000 MacBook does not support the program. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 27, 2021 Share Posted December 27, 2021 Takes time to get licensing and approval from Apple, then run thru all the tests on any update to be certain it works before letting it loose. Quote Link to comment Share on other sites More sharing options...
nanoplane Posted April 19, 2022 Share Posted April 19, 2022 I have the same problem... it's now 5 months later. Can't install Workbench on Monterey (MacOS 12.3). I have JT59 Variax. --marcel Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 19, 2022 Share Posted April 19, 2022 For JTV guitars you need to use Workbench HD. Quote Link to comment Share on other sites More sharing options...
magsterone Posted April 26, 2022 Author Share Posted April 26, 2022 Any timeframe for the workbench hd and Monterey issue being resolved? thanks Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 26, 2022 Share Posted April 26, 2022 Don't know yet. Keep checking periodically in the M1 compatibility notice in the above section. Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 27, 2022 Share Posted April 27, 2022 On 4/26/2022 at 5:59 PM, magsterone said: Any timeframe for the workbench hd and Monterey issue being resolved? thanks What is the issue you're having exactly? Workbench HD is working fine on Monterey on my M1 Mac mini. When you say it's unable to load, are you talking about the non-verified software warning you get when you try to install it? You can override that by right clicking on the file and selecting "Open". Quote Link to comment Share on other sites More sharing options...
rkemperroar Posted June 10, 2022 Share Posted June 10, 2022 Workbench HD will work with Monterey 12.4. if 1) use the Variax VDI USB interface 2) Variax battery has good charge 3) plug 1/4 inch into guitar to turn ON the variax I can upload/download Variax presets. Note however with my older music system High Sierra I can use the HX Edit to communicate to the Variax and use Workbench HD (through the Helix w/HX Edit) to upload/download/modify Variax presets. I can also switch presets on the Helix and see the changes occur in Workbench HD. With Monterey if I Helix>HD Edit (NO VDI USB just Variax to Helix) and have Workbench HD open if I select Helix presets which have different Variax presets the Workbench HD does not show the correct Variax preset as defined by Helix. It seems like the tone/preset is correct but it does not display properly. Then If I select a Workbench HD Variax model it will randomly go to a different Helix preset and may or may not change the WHD Variax model --- so integration Helix<>HX Edit<>Workbench HD is Not working with Monterey. Quote Link to comment Share on other sites More sharing options...
AR2023 Posted June 30, 2023 Share Posted June 30, 2023 On 4/18/2022 at 8:48 PM, nanoplane said: I have the same problem... it's now 5 months later. Can't install Workbench on Monterey (MacOS 12.3). I have JT59 Variax. --marcel Same deal 7/2023 Quote Link to comment Share on other sites More sharing options...
psarkissian Posted July 5, 2023 Share Posted July 5, 2023 Check the Downloads page on the site for computer OS compatibility. And that it's for Workbench HD. Quote Link to comment Share on other sites More sharing options...
