dsmall2112 Posted February 24, 2022 Share Posted February 24, 2022 Thanks in advance for any suggestions. I am able to get Looper to work on other presets, however I have a particular preset (attached below Acoustic 6str.hlx) in which it doesn't work properly. I am able to add Looper to this preset, and the buttons respond as expected (e.g. for "1 Switch Looper" I can see RED for record and GREEN for playback....and similar visuals for the "6 Switch Looper" I can see the IN/OUT OVERDUB labels and solid/blinking white knob toggles) however nothing is played back (I can't tell if it was recorded and playback volume is 0, or if just not recorded). I've tried removing that effect from the path (remove>>save>>restart>>add back) but same issue. I'm still learning my Helix Floor (running v3.15) so I could be missing the obvious. I believe this issue occurred with 3.11 (what my unit was shipped with in Dec 2021) so don't think it's 3.15 issue. Below is image of "Acoustic 6str.hlx" preset has quite a bit going on. Originally Looper was the very last effect (after last Volume) so I tried moving it around to trigger a positive result. Forgive my experimentations. Acoustic 6str.hlx Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 24, 2022 Share Posted February 24, 2022 There's a lot going on here and so I'm not sure of your intent, but your Output Block Level is assigned to SNAPSHOTS and in the ACOUSTIC Snapshot (SS1) it's set to -120db (OFF). The Looper works fine in the other Snapshots. Quote Link to comment Share on other sites More sharing options...
