Why has no one told me about SNAPSHOT BYPASS?
z3albw1rr
This is not the answer to my prayers (exclusive FS groups would be) but this may be close.
As I understand it, you can have the LT set to 4 Stomps and 4 Snapshots. Then you can have 4 stomps each assigned to a footswitch but NOT have their state change when switching snapshots using snapshot bypass, correct?
That brings up a couple of other questions:
If you are in Stomp/Snap mode, and have the up/down buttons set to Snapshot, what happens if you press "up". Does it just go up one, or does it show 5-8?
What would be tres cool is if I could get to SS 8 by going down 1 from 1, or to 5 by going up 1 from 4. Even if they didn't display. I know about the new "snapshot stacking" feature but I'm not sure how I'd implement that yet because it doesn't give all possible combinations. But at least being able to add a snapshot on either side, where I could still press 1 of the 4 buttons to get back to 1-4 would be really handy.
The UP/DOWN switches can be set to Bank, Preset or Snapshot. When pressed, they INCREMENT or DECREMENT whatever they're set to by 1.
So yes, it doesn't matter what's DISPLAYED, whatever you're on goes up or down by one.
What is "Snapshot Stacking"? Are you referring to the Snapshot Prev/Next function in CommandCenter?
  • Thanks 1
Their BYPASS STATE (ON/OFF), yes. If you manually turn a block ON then switch to a Snapshot where it's been saved as OFF it remains ON and vice versa.
It does NOT work for parameter settings, only Bypass.
  • Thanks 1
Yes probably. It's where you can make a FS take you to SS2 when you're on SS1. Then once in SS2, that same FS can now take you back to 1, or you could set it to take you to 3, and so on.
