raulgranada Posted June 18, 2022 Share Posted June 18, 2022 how to connect an external wah pedal to pod go? thanks Quote Link to comment Share on other sites More sharing options...
NBell Posted June 21, 2022 Share Posted June 21, 2022 Hi raulgranada, There's ultimately two ways you could connect your external wah to POD GO. 1) You can always run your external wah before POD Go (Guitar > External Wah > Guitar In of POD Go) this would obviously place your wah before all blocks in POD Go. 2) Alternatively, you can connect your external wah through POD Go's FX Loop with the option to move the effects loop block to the beginning (or anywhere) of your signal chain, this connection would require two cables connected from your wah to POD Go's FX Loop: Connect the first cable from POD Go's FX Loop Send to your wahs Input, then connect the second cable from your wahs output to POD Go's FX Loop Return. Quote Link to comment Share on other sites More sharing options...
voxman55 Posted June 21, 2022 Share Posted June 21, 2022 On 6/21/2022 at 2:41 AM, NBell said: Hi raulgranada, There's ultimately two ways you could connect your external wah to POD GO. 1) You can always run your external wah before POD Go (Guitar > External Wah > Guitar In of POD Go) this would obviously place your wah before all blocks in POD Go. 2) Alternatively, you can connect your external wah through POD Go's FX Loop with the option to move the effects loop block to the beginning (or anywhere) of your signal chain, this connection would require two cables connected from your wah to POD Go's FX Loop: Connect the first cable from POD Go's FX Loop Send to your wahs Input, then connect the second cable from your wahs output to POD Go's FX Loop Return. Agreed - but generally to sound better you'll want a wah at the front of your signal chain. 1 Quote Link to comment Share on other sites More sharing options...
alainmaiki Posted August 7, 2024 Share Posted August 7, 2024 I have the PODGO Wireless Pedal. I have a Crybaby Way pedal. I still want to use the Wireless G10 and use the external crybaby was, how can I connect external crybaby was and still have wireless input setup on my guitar? Is it possible? or just possible with guitar cable wired? Quote Link to comment Share on other sites More sharing options...
theElevators Posted August 12, 2024 Share Posted August 12, 2024 On 8/7/2024 at 3:48 PM, alainmaiki said: I have the PODGO Wireless Pedal. I have a Crybaby Way pedal. I still want to use the Wireless G10 and use the external crybaby was, how can I connect external crybaby was and still have wireless input setup on my guitar? Is it possible? or just possible with guitar cable wired? Use the effects loop. That way you retain the wireless functionality, and the effects loop will only have your wah. Place it in the beginning of your chain. Quote Link to comment Share on other sites More sharing options...
