shawnmx Posted September 4, 2022 Share Posted September 4, 2022 Just wondering if this is even possible. Both guitars use tremolo bridges. PCBs and blocks look different for both bridges. But the connection at the end of the cable for both bridges looks similar. I know there are other factors when swapping bridges on any guitar, not just Variax, as well. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted September 7, 2022 Share Posted September 7, 2022 The way the neck sits in the neck pocket of the 69, and how the bridge orients to it, verses the on-the-deck mounting of the Standard bridge, the slight difference in strings spread, make it a bad idea. The two mounting cavities would leave you with a problem of clearance for good tremolo use. The way the cable mounts from bridge to main board would complicate that even more. Unless you have a lot of experience working on these two guitar, it would be ill advise. Also,... mods like that would be an unsupported modification. So if this ended up on my bench, chances are I would have to return it untouched. 1 Quote Link to comment Share on other sites More sharing options...
shawnmx Posted September 7, 2022 Author Share Posted September 7, 2022 Thanks for the clarification! Quote Link to comment Share on other sites More sharing options...
psarkissian Posted September 7, 2022 Share Posted September 7, 2022 No problem. 1 Quote Link to comment Share on other sites More sharing options...
