Battue Posted November 6, 2022 Share Posted November 6, 2022 Hey Guys, i had a big problem because my macbook go into sleeping mode during the update from 3.15 to 3.5. The device starts only with the splash screen Firmware 3.5. It doesn't start trough Mainsoftware. Its not possible to connect the device to HX Edit and also no connection with the line 6 updater is possible. The factory reset with button 2&3 also doesn't work? Do you have another tip for me to restart the update process? Best regards Patrick Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 6, 2022 Share Posted November 6, 2022 Line 6 Updater should work. You just have to have HX Edit completed closed for Updater to see the Stomp. Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 6, 2022 Share Posted November 6, 2022 On 11/6/2022 at 10:00 AM, Battue said: Do you have another tip for me to restart the update process? Go here and follow these instructions to recover from a failed update. Do not allow your Mac to enter sleep mode, or run any other background operations during the installation. Hope this helps makes sense. Quote Link to comment Share on other sites More sharing options...
Battue Posted November 6, 2022 Author Share Posted November 6, 2022 I think i have tried nearly everything :( other usb cables, a fresh macbook only install line6 Updater tool. I tried older versions of the tool. The only think i can't try, is to do this with a windows systems. My windows PCs are looked for company installing only :( I believe this would be a case for the support. But many many thanks for your help!!! Quote Link to comment Share on other sites More sharing options...
