Which split best for unaffected path A and optional parallel B?
Elephantstomp
Hello,
after a signal split (Y-split) path A became lower in output than it was before.
How much lower exactly?
How much do I have to increase the output of path A to get it as loud as it would be without the split?
And will path A sound exactly the same then? I am going to use path B only in one of three snapshots of a preset and volume-wise just to taste.
This preset is mono.
Thanks!
Edit:
I found out it´s -3dB per path (at the merge position).
What would be the best split for maintaining path A as it is and having Path B parallel?
Would it be the A/B split? (Because it doesn´t mess with volumes. And I have "minus infinity" dB instead of -60dB (bleeding), what would be good to deactivate path B)
  • Elephantstomp changed the title to Which split best for unaffected path A and optional parallel B?
On 11/7/2022 at 7:52 AM, Elephantstomp said:
Hello,
Thanks!
Edit:
Maybe this will help:-
