jeffjohn Posted November 9, 2022 Share Posted November 9, 2022 Hi Anyone else found this after installing the 3.50 update? I done a back up before instal then restored back up and all my global settings had changed!!! Quote Link to comment Share on other sites More sharing options...
PierM Posted November 9, 2022 Share Posted November 9, 2022 Mine are exactly as the one I saved in the backup. Are you sure you didnt reset globals after the update and the bkp restore? Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted November 9, 2022 Share Posted November 9, 2022 On 11/9/2022 at 2:04 PM, jeffjohn said: Hi Anyone else found this after installing the 3.50 update? I done a back up before instal then restored back up and all my global settings had changed!!! If you restored a backup that you took after doing a factory reset, you can end up with the default factory global settings. Another possibility is that you unchecked the Global settings when you restored your old backup. Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 9, 2022 Share Posted November 9, 2022 On 11/9/2022 at 7:04 PM, jeffjohn said: I done a back up before instal then restored back up and all my global settings had changed!!! When restoring from a backup, you have the option to install only the Global settings if you wish, that will leave all your other stuff as is. If you made another backup recently, you could possibly recover you Globals from that backup. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
