(Almost??) bricked my Stomp trying to update it, need help
Papug
So here's the deal. My Stomp's firmware was 3.11 and I felt like it was time for an update, there's also that fancy 3.50 update on their website so I went for it. Using HX Edit wasn't an option because it wouldn't work online, so I went for Line 6 updater, downloaded the firmware, did the thing in offline mode and... it skipped me the whole update (only showed that red bar once in a million attempts), gave an error and stuck the device at that start splash screen. Now all I can do is turn on my Stomp in Update mode (power on + PAGE >), befriend it again with Line 6 updater, try to install *any* firmware (the initial 3.11, 3.15 or 3.50) and still get nothing in the end. Any advice here guys? D:
On 12/3/2022 at 1:37 PM, Papug said:
. Using HX Edit wasn't an option because it wouldn't work online, so I went for Line 6 updater, ….
First, make sure HX Edit is not running while you run the Updater program.  If that doesn’t fix it, …
I would get the HX Edit issue resolved first, and then follow the update instructions.
Please provide more details about your HX Edit online issue.
Well, in case the device is stuck already, there's no point in trying with HX Edit again as HX Edit simply won't even connect.
To Papug:
- Make sure the Stomp is connected directly to your PC, using a quality USB cable.
- Make sure you don't sign into your account with the Line 6 Updater.
- Obviously make sure the Updater is the latest version and the firmware is the proper revision.
  • 7 months later...
On 7/5/2023 at 12:58 PM, Papug said:
Bump. I don't remember how I fixed it last time, but it happened again on 3.50-3.60 update, Jesus! Please help, I'm damn useless
Here we go - one more time from the top. Go here and follow the instructions to the letter. If you feel unsure about performing the update, please find a 14 year old computer geek to do it for you.
Hope this helps/makes sense
