Default Setlist: Templates...description?
JasonHTX
Hi! New Helix LT owner here. Browsed through the manual, and didn't find what I was looking for. The default Setlists has a folder at the very last called "Templates". There are quite a few presets there - most of them obvious, such as "Guitar + Vocals" or "DAW Remote MMC", but there are a few at the top of the preset list that I just don't know how (or why, really) to use them. Is there documentation anywhere that describes/defines all the default patches? Kinda like how you can see the table in the manual for "Blocks" that describe the emulations? Anything like that? Just looking at the preset and deconstructing it seems mostly unproductive.
Any guidance?
Most "template presets" are about the routing and/or pedal assignment, not so much the tones you might stumble on. The titles are usually self explanatory... if you don't understand what is said, maybe you just aren't familiar with that term/technology?
The nuts and bolts of the template may have to be deconstructed (eg: which loop is used in the 4 cable template) but the title is still self-explanatory.
Any guidance?
Maybe if you post the presets' names other users will recognize their function. If you don't feel like typing the names, you can export them as individual presets by highlighting the ones in question and then just cut and paste the names into your post.
  • 3 months later...
Hello,
I also found this setlist, and it seems very helpful, but the names and the content mismatches. The name is usually in the preset before the correct content.
04A Guitar + Vocals contains 4 channels (Guit-Mic-Bass-Key)
04B Gtr+Vox+Bas+Keys contains a setting which could be used for the DT amps. Which is 04C...
Anybody else with this (luxury) issue?
Thanks
Bye
HeinzSchlunz
