HELIX LT - GOOD SPEAKER FOR BASS
pavelo01
Hello
It's time to start play on guitar bass (played on guitar several years).
The best solution for speaker to connect with helix is?
I have presets for bass guitar on helix and they sound good on my speaker  Headrush 108
but are there people who have better solution (cabinet or active speaker)?
I wouldn't care much of FRFR for Bass honestly, and I'd just hunt for a good PA 15" speaker, with a "flattish" response giving you some juice at 40Hz without have to implement a subwoofer. Even something capable of producing -3dB at ~55Hz would do the job. That's if we are talking about a standard 4 strings bass, tuned E standard. If you go lower than that, maybe with a 5 strings, you need big and heavy stuff. It always depends what you need for; gigging? bedroom practice? stage monitor?
8" for bass is a bit weak (the 108 FR starts at 52Hz at -12dB, your E string fundamental sits at 41Hz), unless you are playing at bedroom levels and you don't care much for fundamentals.
  • Upvote 2
Having a modeler does not in any way determine what kind of amp you need.
I've been using my HR FRFR112.
Frequency Response 53hz-22khz +/-3db, Frequency Range 46hz-22khz -10db.
For home/jam/small gigs it does the job. It does, however, have a very "modern" sound.
TBH, if I were to get back into gigging on bass, I'd go for a real bass amp.
If you're using an active Ibanez and playing a lot of "slap'n'pop" then look for something with multiple 10" speakers.
For a more traditional sound, a Fender P-Bass into a 300watt/15" Fender Rumble is about as far on the "traditional" end as you can get for reasonable bucks.
Of course, if I had roadies it would be an SVT and a "fridge"... :-)
Of course, there's lots of ways to go.
You might want to go over to Talkbass and just cruise around the amp threads to see who's using what these days.
