shawnt113 Posted February 27, 2023 Share Posted February 27, 2023 Apologies if it’s been discussed previously… but as the topic says what’s the closest amps in the real world that the Badonk could represent? Quote Link to comment Share on other sites More sharing options...
datacommando Posted February 27, 2023 Share Posted February 27, 2023 On 2/27/2023 at 3:51 AM, shawnt113 said: Apologies if it’s been discussed previously… but as the topic says what’s the closest amps in the real world that the Badonk could represent? Hi, Copied from the description provided on https://helixhelp.com/models The Line 6 is Badonk is based on a Line 6 original inspired by the original high gain Big Bottom model Synopsis To create the Line 6 Badonk, the Big Bottom model from the XT code was rebuilt using new tools so that the overall EQ and pre-post distortion filtering matched. The previous tone stack was a little limited, so it was tuned up to have more range and provide a realistic, interactive response. To make this model feel more like a full amp, the power amp from the Fatality model (mesa rectifier mod) was added then tweaked slightly to reinforce the overall EQ curve of the Big Bottom. Tone Secret: The Big Bottom does not have a crap-load of low frequency. Instead, it is an amp with a slightly more than average amount of low end that can really hold together while being fed a lot of low frequency. It holds together well with heavily detuned guitars. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted February 27, 2023 Share Posted February 27, 2023 If you want to buy an amp that does the Badonk stuff and more - Amp1 Iridium by Bluguitar. Quote Link to comment Share on other sites More sharing options...
