boynigel Posted March 31, 2023 Share Posted March 31, 2023 I'd been trying to get the LT to change channels on my Bad Cat amps to no avail. Pulled out my Suhr PT15 (non-IR) to see if i could get it to work. Sort of. Following instruction from the manual, i can get the LT to change the amp's channels, but it will only switch between channels 2 and 3. I can't access channel 1 on the amp. I know it can be done though because i saw Pete Thorn do it with his HX Effects in a video. All 3 channels. Unfortunately, said video wasn't a setup how-to video. So to you 3-channel amp users, what am i missing here? Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 1, 2023 Share Posted April 1, 2023 On 3/31/2023 at 11:46 PM, boynigel said: what am i missing here? Pete Thorn? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 1, 2023 Share Posted April 1, 2023 The HXFX has two Ext Amp/Exp Pedal jacks. The LT has only one. With the PT15, it being his signature amp, he probably knows a trick to make it work, probably requiring using both jacks on his HXFX. As for the Bad Cat, knowing the model might be helpful, but I suspect it will be a similar solution. PT frequents the D&M forum on TGP, you might try asking over there. No, I don't know his handle, but you can try searching. Quote Link to comment Share on other sites More sharing options...
boynigel Posted April 1, 2023 Author Share Posted April 1, 2023 On 3/31/2023 at 8:04 PM, rd2rk said: you might try asking over there. actually i reached him via Instagram. I didn't want to bug him for a "tutorial" so i just asked him to clarify if it could be done with a single TRS cable. He confirmed that it could "definitely" be done with a TRS. He said that one switch goes between channel one and two and the second switch goes between 2/3. Said it's been a while since he's done it, so he couldn't remember all the details without digging out his HX. Quote Link to comment Share on other sites More sharing options...
boynigel Posted April 1, 2023 Author Share Posted April 1, 2023 On 3/31/2023 at 8:04 PM, rd2rk said: The HXFX has two Ext Amp/Exp Pedal jacks i was just thinking about this and realized be that as it may, the PT15 amp only has one foot switch input jack so he couldn't have been utilizing both Ext Amp outputs on the HX FX Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 1, 2023 Share Posted April 1, 2023 On 3/31/2023 at 6:53 PM, boynigel said: i was just thinking about this and realized be that as it may, the PT15 amp only has one foot switch input jack so he couldn't have been utilizing both Ext Amp outputs on the HX FX Adaptors. 1/4" TRS>whatever it takes + whatever settings on the HXFX. I'm sure he'll explain it when he gets back to you... 1 Quote Link to comment Share on other sites More sharing options...
