Jalbatross Posted July 25, 2023 Share Posted July 25, 2023 Ok so the video explains but basically Im trying to set up my exp pedal with my HX Stomp for delay time/repeat fuctions while always being able to also use tap tempo. Setting note values doesn't achieve the effect Im looking for (pitch/time stretch warble) with my my exp pedal sweep. If I set the time with ms/sec it works but then I can't use tap? Please help Here's what Im trying to do: Quote Link to comment Share on other sites More sharing options...
Schmalle Posted July 25, 2023 Share Posted July 25, 2023 Unfortunately you can't have both. Either you set the delay's Time parameter to a duration in seconds (then the expression pedal works) or you set it to a note value (then you can use the tap function). For it to be possible the Time parameter would need to be split into two parameters: time and note value. Quote Link to comment Share on other sites More sharing options...
datacommando Posted July 25, 2023 Share Posted July 25, 2023 On 7/25/2023 at 7:00 PM, Jalbatross said: Setting note values doesn't achieve the effect Im looking for (pitch/time stretch warble) with my my exp pedal sweep. Hi, Check your Global Settings > Preferences > Page 1 > Knob3 > Tempo Pitch > “Authentic” should give you the pitch warble you want from the Expression Pedal. Hope this helps makes sense. Quote Link to comment Share on other sites More sharing options...
Jalbatross Posted July 25, 2023 Author Share Posted July 25, 2023 On 7/25/2023 at 1:54 PM, datacommando said: Check your Global Settings > Preferences > Page 1 > Knob3 > Tempo Pitch > “Authentic” should give you the pitch warble you want from the Expression Pedal. I have it set to "Authentic" and it sounds fine when set to ms/sec but then I can't use tap. When I try something similar by setting heel to 1/4 note and toe to 1/2 note it just sounds like a quick little glitchy sound and no organic time knob effect. Quote Link to comment Share on other sites More sharing options...
Jalbatross Posted July 25, 2023 Author Share Posted July 25, 2023 On 7/25/2023 at 1:38 PM, Schmalle said: Unfortunately you can't have both. Either you set the delay's Time parameter to a duration in seconds (then the expression pedal works) or you set it to a note value (then you can use the tap function). For it to be possible the Time parameter would need to be split into two parameters: time and note value. I think you might be right but it seems crazy that the helix can't do something so simple that the DL4 always does. It might be a deal breaker on this unit for me since I need agility with my delays (for experimental dubbing, etc). Quote Link to comment Share on other sites More sharing options...
Jalbatross Posted July 25, 2023 Author Share Posted July 25, 2023 Welp... I'm realizing that with certain patches I can actual achieve a nice time sweep by setting heel to 1/4 note and toe to whole note for instance. Other patches just kind of glitch out unfortunately. The vintage digital does it fine... 1 Quote Link to comment Share on other sites More sharing options...
