Software for Shuriken Variax
Jae1978
There is software called Workbench HD that is an editor for later model Variax guitars including the Shuriken. Line 6 Monkey is used to install the Variax firmware. In either case you need to connect your Variax to a computer using the Variax USB Hardware Interface which is included with new Line 6 Shuriken guitars. You should have that unless you bought it used and the seller did not include it.
Monkey is used for updating the Flash memory. Workbench HD would be used to customize patches and to get the Shuriken bundle,... if it isn't already loaded in.
More information on the Knowledge Base,... https://line6.com/support/search/?&q=shuriken &type=cms_records1&search_and_or=or&sortby=relevancy
  • 2 weeks later...
  • 6 months later...
