DELAYS: Working out how to get certain delay times
Aurasphere_au
Based on my previous thread...am trying to get pretty much
Left Side Delay
   3 x 16ths (Dotted 8th right?)
Right Side Delay
   6 x 16ths (Dotted 1/4 right)
Either Ableton is wrong of the delays in Helix are wrong when I try and set the same...as they sound rhythmically completely different...unless I have the above interpretation wrong
Also: there seems to be no obvious way of getting dotted triplets?
A dot adds 50% again to a note's value: it multiplies the length of a note by 3/2.
A triplet makes 3 copies of a note fit into the space of 2. (Three eighth note triplets in the space of two eighth notes.) So the triplet sign multiplies the length of a note by 2/3.
2/3 * 3/2 = 1.
If you really need precision you could set your timings in milliseconds, but that requires that you don’t deviate from the overall time setting - no jazz!
NOTE VALUE
NOTES
DOTTED
TRIPLETS
1/1
(1 Bar)
2000 ms / 0.5 Hz
3000 ms / 0.33 Hz
1333.33 ms / 0.75 Hz
1/2
(2 Beats)
1000 ms / 1 Hz
1500 ms / 0.67 Hz
666.67 ms / 1.5 Hz
1/4
(1 Beat)
500 ms / 2 Hz
750 ms / 1.33 Hz
333.33 ms / 3 Hz
1/8
250 ms / 4 Hz
375 ms / 2.67 Hz
166.67 ms / 6 Hz
1/16
125 ms / 8 Hz
187.5 ms / 5.33 Hz
83.33 ms / 12 Hz
1/32
62.5 ms / 16 Hz
93.75 ms / 10.67 Hz
41.67 ms / 24 Hz
1/64
31.25 ms / 32 Hz
46.88 ms / 21.33 Hz
20.83 ms / 48 Hz
Hope this helps/makes sense.
On 9/8/2023 at 6:38 PM, DunedinDragon said:
I believe Ableton provides a mathematically correct triplet which is 1.33 + 1.33 + 1.33 = 4 standard beats rounded to the nearest whole number.  I'm not sure any of the delays in the Helix have any provision for that level of precision.
Yep thats what I thought...cubase has it as well
Yeah thats not going to work as the feel at each gig is different and I normally tap tempo...its usually within a couple of beats but its incredible how that changes...its normally set by what you feel in the crowd/audience. On top of that add the micro groove and if you are tired...playing a couple of ms behind etc
Thanks anyway. Ideally would love to be able to patch stuff between plugins really but I just left a vote for helix native to do that...if it did I would set up a mini pc rig instead of Helix for sure
If it changes in Helix Native it changes in all Helix units.  It's a single code base
