drewster77123 Posted September 19, 2023 Share Posted September 19, 2023 Hi. I'm not sure how to explain this. It seems that my board is suddenly producing sounds similar to if my guitar knob is turned to the bass tone. ( this is the only way I can explain it) I have tried everything. amp. cables etc etc. anyone have any insight?? thanks! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 19, 2023 Share Posted September 19, 2023 Global Settings>Preferences>Auto Impedance = First Enabled In your presets: Input Block>Guitar In Z = Auto The Input Impedance determines how the guitar's pickups are "loaded". When the Input Impedance is less than 1M (standard for amp inputs) high frequencies are attenuated. This is key to getting authentic tone from certain effects, particularly fuzzes, whose inputs are <1M. Quote Link to comment Share on other sites More sharing options...
drewster77123 Posted September 19, 2023 Author Share Posted September 19, 2023 ooh?! ok. I'll try asap, but I find it strange that it just suddenly happened... either way, thank you for replying. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 19, 2023 Share Posted September 19, 2023 If that's not the issue, perform a factory reset (backup first!). Usually cures random came-out-of-nowhere type problems. 1 Quote Link to comment Share on other sites More sharing options...
drewster77123 Posted September 20, 2023 Author Share Posted September 20, 2023 ok. thanks again Quote Link to comment Share on other sites More sharing options...
theElevators Posted September 21, 2023 Share Posted September 21, 2023 On 9/19/2023 at 2:15 PM, drewster77123 said: Hi. I'm not sure how to explain this. It seems that my board is suddenly producing sounds similar to if my guitar knob is turned to the bass tone. ( this is the only way I can explain it) I have tried everything. amp. cables etc etc. anyone have any insight?? thanks! If you didn't change anything on the Helix, it could be a bad 1/4" cable. Also, check if your amp is ok (or whatever you run your Helix through). Did you tough your global EQ? Quote Link to comment Share on other sites More sharing options...
