wobrien54 Posted October 12, 2023 Share Posted October 12, 2023 What software is best to use for easy downloads of purchased IRs into my pod go? I tried 1 online but cant get them into the IR section of my pod go. any recommendations? TIA Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 12, 2023 Share Posted October 12, 2023 You need to use POD Go Edit. You can drag/drop the individual IR files into the IR slots in the Edit program. 1 Quote Link to comment Share on other sites More sharing options...
voxman55 Posted October 12, 2023 Share Posted October 12, 2023 To update Pod Go firmware, create backups, create set lists, and import/export IR's you should be using Pod Go Edit. The latest Pod Go Edit is v1.41 if you are a PC user or v1.42 if you are a Mac user (essentially the same as v1.40 but with minor bug fixes only). The latest Pod Go firmware is still v1.40. Public release of the new Pod Go firmware upgrade (v2.0) is anticipated within the next 30 days (Line 6 accidentally let slip, albeit now withdrawn, a copy of the planned press release dated for 7/11 into the public domain, but the date could change). Whenever a new firmware upgrade is launched, there are instructions that will always refer to updating Pod Go Edit first and then letting Pod Go Edit create backups and guide you through the Pod Go firmware set-up process. You can get the latest Pod Go Edit from here: https://line6.com/software/index.html Just select Pod Go, & Pod Go Edit & your operating system. As @silverhead said, it's then very simple to drag/drop new IR's in. Make sure you are draggng in the .wav file version and that you have first exported IR's collectively into separate IR wav files that may be provided as a Zip file - you can't import a set of IR's as a zip file. Don't worry about file sixe - Pod Go Edit adjusts these automatically. Quote Link to comment Share on other sites More sharing options...
wobrien54 Posted October 12, 2023 Author Share Posted October 12, 2023 Thanks for the quick response. I am using pod go edit (1.40), I couldn't download 1.41 because Im running windows 7, my problem is more towards the format the IR is after I download it to my computer, Voxman55 you mentioned having the IR as a .wav file, they do have .wav after the IR, but when I try to drag them into the pod go I still get the circle with the line thru it and it wont go into the IR section of the pod go, maybe I should I download a different type of wav file software to convert the IR? Quote Link to comment Share on other sites More sharing options...
voxman55 Posted October 12, 2023 Share Posted October 12, 2023 v1. 40 is fine, no need to upgrade. Try importing the IR rather than drag and drop. 1 Quote Link to comment Share on other sites More sharing options...
wobrien54 Posted October 13, 2023 Author Share Posted October 13, 2023 Thanks Voxman55 I’ll try that Quote Link to comment Share on other sites More sharing options...
voxman55 Posted October 13, 2023 Share Posted October 13, 2023 On 10/13/2023 at 10:04 AM, wobrien54 said: Thanks Voxman55 I’ll try that Just a thought, but i'm wondering if it might be because of the length of the file name. Pod Go won't accept it if it's too long. Try 'save as' and renaming it to something reasonably short (but make sure you keep the .WAV suffix) and then try drag 'n drop. 1 Quote Link to comment Share on other sites More sharing options...
wobrien54 Posted October 13, 2023 Author Share Posted October 13, 2023 OK I will try that as well, thanks again!! Quote Link to comment Share on other sites More sharing options...
