cheesedoodle Posted November 19, 2023 Share Posted November 19, 2023 Although there are a million threads on level setting for the Helix, I have found non that directly addresses this issue (somewhat inexplicably). Here's the problem, then I'll describe my settings. I am using the HX Stomp as a pedalboard (i.e., no amp or cab blocks) in front of my amp. The input signal level coming from the Stomp is way lower (about 25-30 db lower) than the signal level going into the amp when I just plug my guitar straight into the amp. My HX Stomp settings are all default: Input In-Z is on auto; pad is off; main output is set to 0db. Under global settings, both input and output are set to INSTRUMENT level. With these settings, and all blocks empty—effectively bypassing any Helix processing—it would seem that the Helix should be acting like a stomp box on bypass, and just pass through the signal from the guitar to the amp unchanged. But something in the Helix is causing the signal level to drop drastically between the guitar and the amp. I could crank up the output of the Stomp, but at +20db it doesn't even have enough gain to make up for the signal drop. I might be able to get there by adding a volume block, but it seem ridiculous to have to max out the gain on the Stomp just to get it back to what the amp considers to be instrument level. Any thoughts on how to simply have the Stomp act level-wise like a regular stomp box? I have also read opinions that the Helix actually prefers a lower input (hence the addition of the pad feature) which seems bonkers to me given how low the level seems to be. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 19, 2023 Share Posted November 19, 2023 Sorry for the basic question, but you don’t mention it…. Is the Volume knob (top panel) set at or nearly at its max level? 2 Quote Link to comment Share on other sites More sharing options...
codamedia Posted November 19, 2023 Share Posted November 19, 2023 On 11/19/2023 at 6:37 AM, silverhead said: Sorry for the basic question, but you don’t mention it…. Is the Volume knob (top panel) set at or nearly at its max level? ^^^ This ^^^ is the first place to check. The volume should be at full for unity. Also, check the output block on the preset you are working with to make sure it is not set to attenuate the level. Check the Global EQ to make sure it isn't turned on an attenuating your level. (edit to add because of the @MGW-Albertapost below) One last thing... don't assume anything! Using the stomp means you are also using 1 more cable... double/triple check your cables and connections to make sure they are good. If you absolutely can't solve the problem... set your outputs to "line level" and turn down the volume control to create unity. Make note of that volume position for all future use. (Note: This should not be necessary, but it works) 1 Quote Link to comment Share on other sites More sharing options...
cheesedoodle Posted November 21, 2023 Author Share Posted November 21, 2023 Thanks for all the replies. The volume knob was indeed the problem and the solution—thank you for pointing that out. I had previously used the outputs at line level going to monitors and had not used the Stomp in front of an amp. So it seems stupid of me in hindsight, but I didn’t consider cranking the physical volume knob in this context. Problem solved. Thanks so much for your help! Quote Link to comment Share on other sites More sharing options...
