dtwomey Posted December 15, 2023 Share Posted December 15, 2023 I got my HX One yesterday and went to try it out last night. I have it set up in pre/post on my pedalboard. It all works as it should, but when I have the HX One in my signal chain it is adding terrible noise to some of my drive pedals - so much so that they are unusable. Using the noise gate on the HX One makes no difference and I am not sure how to remedy it. I took the HX One out of the chain again to check that it wasn't anything else causing interference and everything is fine. I would love to remedy this as I really like the HX One otherwise. If I can't fix the issue then I will have to return the HX One. Does anyone have any ideas as to help? Thanks 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 15, 2023 Share Posted December 15, 2023 Make sure your Output setting is appropriate for your setup. See manual pg 26 Setting Proper Levels. Quote Link to comment Share on other sites More sharing options...
StratMat59 Posted December 22, 2023 Share Posted December 22, 2023 Exactly the same here ... wanted to make myself a x-mas present ... big disappointment. Running it in 4CM into a Bluguitar Amp1. Crazy that Line6 did not remedy this for good (HX Effects had the prob back in 2019 or so ...). It needs to go back I am afraid. Any useful reply from Line6??? https://youtu.be/MvNk86m8VXc https://www.youtube.com/watch?v=giKZXMwU0yc 1 Quote Link to comment Share on other sites More sharing options...
sonnydinkelaar Posted December 29, 2023 Share Posted December 29, 2023 Got the same problem chain is: guitar - HXone (pre) - Boss SD-1 - JCM800(cranked pre-amp) - Chorus - HXone (post) - dalay - return. I don't have the problem without the HXone so my quess is that the HXone's noise is just loud enough to get really fking noisy when going to a SD-1 and cranked JCM. It would be nice if Line6 is responding to this problem :) Quote Link to comment Share on other sites More sharing options...
juecker Posted January 8, 2024 Share Posted January 8, 2024 A couple of work-arounds for the HX One raising your overall noise floor (for me it was a lot of hiss, but if there's any other noise in your signal chain it'll make that more apparent, too) are to set it to True Bypass - so that it's out of the signal chain when it's off - or using the noise gate. Otherwise - as others have mentioned - having the HX One in your signal path before drive pedals really makes for a LOT of added noise. That was really problematic for me. Disclaimer: When I asked about this issue elsewhere, I had some people telling me their units were dead silent. I don't know if I should attribute that to everyone's hearing being different or manufacturing tolerances. I just know that in my case I was running an otherwise very noise-free setup (CIOKS DC7 power supply into a Fuhrman AC-215 power conditioner) and the HX One was the only thing adding noticeable noise to my rig). Quote Link to comment Share on other sites More sharing options...
RussellConn Posted January 10, 2024 Share Posted January 10, 2024 I thought, It only happend with me. Quote Link to comment Share on other sites More sharing options...
slotek Posted February 25, 2024 Share Posted February 25, 2024 Some dirt pedals do not work properly with a buffered input signal. For example, I have two analog "amp-in-a-box" style distortion pedals (ZVex Distortron, Wampler Plexi Drive Mini) that either hum or hiss loudly when processing a buffered signal such as: 1) the bypassed output of the HX One when the Bypass Type parameter is set to "DSP Bypass" mode, and 2) from what I can tell, the effected output of the HX One (regardless of the Bypass Type setting). I have only tested a few pedals, but for the record, the Fulltone OCD and the JHS Screamer seem to play nicely after the HX One pedal. I have a few other pedals that include a buffer, some of which can be disabled via an internal DIP switch. The nature of the noisy interference differs depends on the type of buffer circuit used in any given pedal. Diagnosing these issues takes a lot of trial and error. I had to test a simplified signal chain (guitar -> HX One -> dirt pedal -> amp) to figure out the source of the interference. So far, I am really happy with the HX One either at the end of my signal chain in front of the amp or next to the other digital time-modulating reverb and delay pedals in my effects loop. Quote Link to comment Share on other sites More sharing options...
Rimoceros Posted March 7, 2024 Share Posted March 7, 2024 On 12/22/2023 at 9:47 AM, StratMat59 said: Exactly the same here ... wanted to make myself a x-mas present ... big disappointment. Running it in 4CM into a Bluguitar Amp1. Crazy that Line6 did not remedy this for good (HX Effects had the prob back in 2019 or so ...). It needs to go back I am afraid. Any useful reply from Line6??? https://youtu.be/MvNk86m8VXc https://www.youtube.com/watch?v=giKZXMwU0yc Same issue here when using it with my Bluguitar Amp1 Iridium Edition in the Classic or Vintage channel (no problems whatsoever, when using my HX Stomp). Unfortunate, because I really want this to work as an ultra-compact Amp1 gigging-solution. Line 6 replied the following: _________________________________________ Hi, HX One cannot be compared with HX Effects, these are two completely different devices and the issue described is not the same there. please try this with another setup (like another amp, no pedalboard, but HX One directly) if you already got a 2nd HX One as replacement this is no hardware issue, so it seems to be an issue with this combination of devices. We have not seen similar issues with other setups. Unfortunately we don't test HX One with Blu Guitar Amps and cannot tell if there are issues in such setups. If you got a DI box you can also insert it in the signal path as a test ________________________________________ I will further investigate this issue and come back here, when I have found out more. Quote Link to comment Share on other sites More sharing options...
dtwomey Posted March 7, 2024 Author Share Posted March 7, 2024 On 1/8/2024 at 5:46 PM, juecker said: A couple of work-arounds for the HX One raising your overall noise floor (for me it was a lot of hiss, but if there's any other noise in your signal chain it'll make that more apparent, too) are to set it to True Bypass - so that it's out of the signal chain when it's off - or using the noise gate. Otherwise - as others have mentioned - having the HX One in your signal path before drive pedals really makes for a LOT of added noise. That was really problematic for me. Disclaimer: When I asked about this issue elsewhere, I had some people telling me their units were dead silent. I don't know if I should attribute that to everyone's hearing being different or manufacturing tolerances. I just know that in my case I was running an otherwise very noise-free setup (CIOKS DC7 power supply into a Fuhrman AC-215 power conditioner) and the HX One was the only thing adding noticeable noise to my rig). Setting it to true bypass doesn’t work with pre/post though Quote Link to comment Share on other sites More sharing options...
dtwomey Posted March 7, 2024 Author Share Posted March 7, 2024 On 2/25/2024 at 6:40 PM, slotek said: Some dirt pedals do not work properly with a buffered input signal. For example, I have two analog "amp-in-a-box" style distortion pedals (ZVex Distortron, Wampler Plexi Drive Mini) that either hum or hiss loudly when processing a buffered signal such as: 1) the bypassed output of the HX One when the Bypass Type parameter is set to "DSP Bypass" mode, and 2) from what I can tell, the effected output of the HX One (regardless of the Bypass Type setting). I have only tested a few pedals, but for the record, the Fulltone OCD and the JHS Screamer seem to play nicely after the HX One pedal. I have a few other pedals that include a buffer, some of which can be disabled via an internal DIP switch. The nature of the noisy interference differs depends on the type of buffer circuit used in any given pedal. Diagnosing these issues takes a lot of trial and error. I had to test a simplified signal chain (guitar -> HX One -> dirt pedal -> amp) to figure out the source of the interference. So far, I am really happy with the HX One either at the end of my signal chain in front of the amp or next to the other digital time-modulating reverb and delay pedals in my effects loop. I have plenty of other buffers in the chain that don’t add this noise. It’s just the HX One that is awful Quote Link to comment Share on other sites More sharing options...
Gebbinator Posted March 18, 2024 Share Posted March 18, 2024 Hi together, I just got my HX One. I wanted to use it with my BluGuitar Amp1 as well, but I got a bunch of Problems: - When connecting in 4 cable Method, and using True bypass Mode, my Amp1 Preamp gets bypassed, too. So its absolutely useless. In addition to that, it gets even more noisy when connecting in 4 cable method - I noticed some „crackling“ noise in the Effects, especially when playing quiet or clean things So far, it seems that its going back. Maybe some FW Updates will fix this? Quote Link to comment Share on other sites More sharing options...
ragingben Posted March 23, 2024 Share Posted March 23, 2024 Same here I'm afraid. Mine arrived yesterday. In front of amp it's very quiet. In the FX loop of my Rockerverb it's also quiet. 4CM using the HX One FX loop it adds an annoying level of hiss. I've messed around switching out cables and etc, it's definitely the HX One. The exact same setup with other pedals switched in in place of the HX One are silent. I'm using a CIOKS DC7 but I've also tried with the included power adapter. It's there in bypass and the gate doesn't deal with it. I've looked at the settings and there's nothing in the globals that affects the noise. It's not a deal breaker as I find using 4CM a pain live, but I was hoping it would work out for home use using the insert loop. I wonder if there's a batch that have this issue, or if simply that the users reporting quiet units aren't using the insert loop and 4CM. Quote Link to comment Share on other sites More sharing options...
akirabass Posted April 20, 2024 Share Posted April 20, 2024 Wouldn't that be caused by the ground loop? Using a cable whose sleeve of one jack is open (unconnected) between the output of the (last) pedal in the loop and the return input of the amp may fix the problem. Quote Link to comment Share on other sites More sharing options...
ragingben Posted May 3, 2024 Share Posted May 3, 2024 Hmmm interesting. It would have made sense for Line6 to put a ground lift switch in if this was the case, it must be a common problem as this is one of tbw advertised ways of using it? Quote Link to comment Share on other sites More sharing options...
akirabass Posted May 5, 2024 Share Posted May 5, 2024 So far as the multi-effect that allow both two- and four-cable methods, the ground lift switch should be necessary for the return connector of "either" the pedal (HX ONE) or the amplifier. Also, more switches (mechanical parts) can cause more troubles. I'm not sure if the ground looping is the culprit of the trouble in this thread, but a ground-lift switch would not be that essential, so long as the problem can be solved by one cable whose shield is disconnected on one side. Quote Link to comment Share on other sites More sharing options...
ryates Posted May 28, 2024 Share Posted May 28, 2024 Got an HX One this weekend and the white noise is unbearable with a distortion pedal after it or in the loop. Tried several distortion pedals including a DOD 250 which is pretty basic. I sent it back. I don't know if it's a "batch" problem or an inherent design flaw but the pedal isn't usable in this scenario. It's a shame because there's so much potential. Quote Link to comment Share on other sites More sharing options...
christianNoir Posted September 10, 2024 Share Posted September 10, 2024 I'm having the same issue, either with an isolated Cioks power supply or original HX One adapter, even with the HX One turned off (maybe in dso bypass). However, unplugging the power to the HX One and the noise is gone. Feeding an HM-2, it increases the noise... But when I feed it through a SD-1, the noise is waaaay over the top. In fact, I thought the noise with the HM-2 was normal, but I was playing at low volumes, so I didn't notice it. After it struck the SD-1 and was so obscene, I tested with the HM-2 and it added its own noise, at a higher frequency. Anyone find a solution other than adding an isolation transformer to the chain? This seems to always be an issue when adding digital gear to analog rigs. I kinda wish the digital gear manufacturers would isolate their own gear right out of the gate. Thanks for any tips. Quote Link to comment Share on other sites More sharing options...
christianNoir Posted October 4, 2024 Share Posted October 4, 2024 Anyone solve this? Try a replacement? Or is it ongoing? I first noticed it with the SD-1, but in DSP Bypass, mine still added noise to everything. Quote Link to comment Share on other sites More sharing options...
Benlop17 Posted October 6, 2024 Share Posted October 6, 2024 Hi, I also bought an Hx One. And even without using any dirt pedal I have a very loud hum when using with my tube amp. This amp is not particularly noisy it is the only pedal that does that to it ... Quote Link to comment Share on other sites More sharing options...
christianNoir Posted October 12, 2024 Share Posted October 12, 2024 On 10/6/2024 at 11:31 AM, Benlop17 said: Hi, I also bought an Hx One. And even without using any dirt pedal I have a very loud hum when using with my tube amp. This amp is not particularly noisy it is the only pedal that does that to it ... In your case, it could be a ground loop of you are using 4-cable method, or a power issue. Have you tried using the original adapter to power the pedal and nothing else? Have you tried the pedal alone, with no other pedals? Have you tried the pedal only in front of the amp or only in the fx loop (not both at the same time)? Hlw about an isolated power supply? Digital effects can do all kinds of strange things when combined with analog ones if you don't have your power situation right. Sometimes, you even need isolation transfirmer(S) on the sufio lines to fix things. Could be an amp issue or issues with the rest of the chain too. I didn't have any hum, just a high noise floor. Quote Link to comment Share on other sites More sharing options...
phruzao Posted January 18, 2025 Share Posted January 18, 2025 Anyone here got a noise free unit!? Quote Link to comment Share on other sites More sharing options...
dtwomey Posted May 9, 2025 Author Share Posted May 9, 2025 I have another HX One since starting this post and it’s the same. Pity as it’s so versatile otherwise Quote Link to comment Share on other sites More sharing options...
mgmmgm2 Posted August 30, 2025 Share Posted August 30, 2025 I have two HX One's. I never had any noise issues with the first one, including when using it with other drive pedals, but I had never used it in 4CM until recently and I usually had it set to true bypass. I got the second unit used. I immediately had noise issues with it, but I eventually figured out that both levels had been set to line level. Once I set them to instrument level I had no problems. After reading about the 4CM noise issues people reported, I tried both of my units in 4CM with both an amp and a Boss IR-2. There was no doubt that it raised the noise floor significantly. I personally wouldn't say that it brought the noise floor up a crazy amount, but both units definitely added noise. It was readily apparent if you switched to true bypass mode while an effect was activated. It did not make the HX One unusable to me, but the issue was readily apparent. It would be nice to see more controlled comparisons across different units in which we know none of the settings are "off"--- line level being used in the wrong context, for example. It would also be nice to know if people reporting no noise in 4CM have actually A/B'd it with the HX One true bypassed (either internally or externally), or maybe even if some folks haven't had amp volume levels high enough to notice it. Power supplies being used might also make a difference. Anyway, it's hard to know what to make of wildly differing reported experiences with noise issues and the HX One. Given that both of my units have the issues in 4CM, I doubt it was just a "bad batch," but who knows? Quote Link to comment Share on other sites More sharing options...
