Helix Rack - Using Front guitar input and aux input for two separate instruments simultaneously
redeveredev
Possibly a bug or possibly something I'm not doing right:
I'm trying to use path 1 for a guitar using the Guitar Input, and trying to use path 2 for a bass guitar using the Aux Input (found on the back)
When I set this up, so that Path 1 uses "Guitar" as the input, and Path 2 uses "Aux" (neither are using the Multi-Input), signal from the front Guitar port is always sent to Path 1 AND Path 2, when I would expect it to be sent to Path 1 only.
If I use the return jacks I can get it to work, but then I'm losing one of the return slots.
Is this a confirmed bug?
Ta very much,
redev
On 1/2/2024 at 11:31 PM, silverhead said:
Are you certain the the guitar signal is processed in Path 2? Both paths are stereo so by default you will hear the guitar in both L and R outputs even though it is only being processed in Path 1.
Yeh, the signal is definitely processed by path 2. I have both paths set to output on the main stereo output (using headphones currently) so that I would hear both at once, but the problem is I'm getting signal into path 2 when I feel that I shouldn't be (I can tell because of the indicator on the input node)
Cheers,
redev
Booted up the preset this morning and wasn't getting the same issue... very bizarre... If it happens again I'll post the preset and/or contact support
Could've been something to do with the firmware update? Only got it yesterday so potentially It needed a restart...
Thank you though!
Yes, that's very likely. A post-installation device reset is part of the recommended firmware update procedures.
  • 2 weeks later...
Ta very much,
redev
Any update?
