drakejohnson Posted January 18, 2024 Share Posted January 18, 2024 If I assign a wah effect to an expression pedal, I can't figure out how then to turn the pedal on and off? It doesn't seem like I can assign the on/off to one of the buttons on the board. Please help! There must be a way to handle this I imagine, maybe something obvious I am missing. Thanks Quote Link to comment Share on other sites More sharing options...
datacommando Posted January 18, 2024 Share Posted January 18, 2024 On 1/18/2024 at 6:13 PM, drakejohnson said: If I assign a wah effect to an expression pedal, I can't figure out how then to turn the pedal on and off? It doesn't seem like I can assign the on/off to one of the buttons on the board. Please help! There must be a way to handle this I imagine, maybe something obvious I am missing. Thanks Hi, When seeking assistance from Forum users it's a really good idea to supply as much information as possible regarding which HX device you are using. Other than that, you could check out the Factory preset "US Double Nrm" (that's slot 01A on my Helix floor) which features both Vol and Wha blocks assigned to EXP1 & 2 respectively. You can check how they are set up using the Controller Assign function on your hardware. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted January 18, 2024 Share Posted January 18, 2024 Read the "Bypass Assign" chapter in the manual. Quote Link to comment Share on other sites More sharing options...
