klasi Posted March 13 Share Posted March 13 If I hit a note or chord hard and let it ring out it will be 25% softer/quieter for about 3-4 seconds and then it will suddenly jump in volume to what it should be at. I swapped out tubes - no difference. I plugged a cable in the effects loop in & out - no difference. I did a factory reset - no difference. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted March 13 Share Posted March 13 Put amp into "Standby" mode, main power on, let it warm up 2-3 minutes, then turn standby switch to on position. Tube amps that make use of a heater element circuit, it's a good idea to let it warm up 2-3 minutes before taking it out of "Standby" mode. Swapping tubes,... I hope they are the specified tubes and that the power tubes are matched pairs,.... DT-50 Series: 12AX7EH Electro-Harmonix approved for the DT50 pre-amps. EL34EH Electro-Harmonix (matched pairs) for the power amps. ... and that the power tubes were correctly biased. Quote Link to comment Share on other sites More sharing options...
klasi Posted March 13 Author Share Posted March 13 I let it warm up for 30+ minutes. No difference. The only setting the volume drop is not noticeable is when it is on Voicing: IV. As for the tube swap. I only did individual tubes one at a time to see if there was a particular tube acting up. And then I only ran the amp for 2-3 minutes per tube. When nothing was different I reinstalled the original tubes. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted March 13 Share Posted March 13 Hmmm,... Quote Link to comment Share on other sites More sharing options...
