denisfarr Posted March 25, 2024 Share Posted March 25, 2024 If I add a send block to a signal path to send the dry signal to a separate output and have effects after it in the path will the signal continue on the path to the effects? Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 25, 2024 Share Posted March 25, 2024 Yes, it should as long as the Send block is active (turned on). If you want the effect-processed signal to be routed back to the Helix Floor you also need to add the associated Return block and cable. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 25, 2024 Share Posted March 25, 2024 The SEND Block has a Parameter called "DRY THRU". Leave that at the default 0db to allow the signal to pass through (or adjust as needed for your connected gear). Set that to -120db to PREVENT pass through. Quote Link to comment Share on other sites More sharing options...
