stenji49 Posted May 4, 2024 Share Posted May 4, 2024 I've had my variax for a couple years, and in fact bought it used. I've been happy enough with all the modeled sounds, but the mags didn't sound right in the 4 position (Neck and Middle). The output was much weaker that the other 4 positions, and did not have the characteristic "quack" that this pickup combination should have. I researched the forum and really didn't find any real solution. From the symptoms, it seemed most likely that the neck pickup was wired in reverse, and so I double checked the pickup wiring and everything was Kosher per the wiring diagram. Hard to screw up, as the pickups each have one white and one black wire, and the board connections are all clearly labeled. Reasoning that there could really be no other answer, I reversed the leads of the neck pickup, soldering the white wire where the black should go and visa versa. Everything is now perfectly normal, all 5 positions have similar volume, and Neck+Middle quacks like a duck. I can only deduce that the neck pickup was mis-manufactured with the white/black wires reversed. As an engineer for 40 years, I can guarantee that my guitar was not the only one with a defective pickup. I hope this is helpful to others. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted May 6, 2024 Share Posted May 6, 2024 Probably needs a set-up, hasn't been service in some time. Pick-up height, worn string nut, couple other things are typical of the quack sound. Doubt it's wiring, that would sound different. But good deduction though. Quote Link to comment Share on other sites More sharing options...
jerseyboy Posted July 27, 2024 Share Posted July 27, 2024 Used guitar someone may have replaced the neck pickup with something that looks identical but all it takes is reverse magnetic or electrical polarity winding… Or, QC just missed one that suffered this fate. If indeed it’s reverse polarity wiring/magnetism that caused your issue. My description of classic 2&4 Strat tone normal parallel polarity is more of a “boink” rather than “quack”. Reverse parallel polarity is the “quack” in my world. Reverse serial polarity more of a “thwack”. Similar but more meat and output to the parallel reverse polarity quack. Quote Link to comment Share on other sites More sharing options...
