USERLINE62K19 Posted May 17, 2024 Share Posted May 17, 2024 Hello, Whenever i plug in my monitor headphones one side of it doesn't works. Earlier it thought it to be an headphone error but i changed several headphone and the problem is same. Is there any setting or anything that i need to change ?? Thanks Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted May 17, 2024 Share Posted May 17, 2024 Assuming you've done your due diligence, the only setting would be.... are your patches set up for 2 sided sound. And that is easy enough to find out - plug a left and right into different speakers and see what happens. Other than that, assuming you did your due diligence, it sounds like the headphone jack has gone bad. Sometimes they can be bent back into place. Sometimes they need soldered. Quote Link to comment Share on other sites More sharing options...
theElevators Posted June 7, 2024 Share Posted June 7, 2024 Check your headphones... do they have a microphone? If so, that could be the explanation. Quote Link to comment Share on other sites More sharing options...
