Overdrive/distortion level issues
Gregory6470
I’ve recently had issues with overdrive/distortion levels going from levels I’ve set then change to 0.0.  I reset the levels, save them and it happens again in no specific amount of time. Anyone had these issues?
While I have not had this specific problem, I have experienced a variety of odd issues any number of times in my years with Helix, and 99% of the time it ended up being user error. It's super easy to change a setting somewhere without realizing it...
Just did a factory reset because I heard that there were some issues with the 3.71 update.?.? After the update all the amp levels were at 0.0. I reset them and saved it.
We'll see if the update works or not. Fingers crossed...
Thanks. I'll check Controller Assign
On 6/21/2024 at 2:04 PM, Schmalle said:
No.
Look up the Level parameter in Controller Assign and make sure it is not assigned to something.
Also, assuming you're in HX Edit and you're using a mouse wheel, make sure the pointer isn't hovering over any parameters you don't want to adjust...
