claudeu Posted August 24, 2024 Share Posted August 24, 2024 Simple question: How can I save adjustments in pesets and snapshots. I read it works automatically. But it never kept the new values. "Save to library" didn´t work either. I couldn´t find a solution in the manual and other threads. Pleas help! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 24, 2024 Share Posted August 24, 2024 Helix Native Pilot's Guide Page 30. Assigning a parameter to the Snapshots Controller As covered in the preceding Snapshots > Block Bypass section, the Bypass state of any block is automatically stored and recalled per snapshot. However, for other parameter types, it is necessary to first create a Snapshots Assignment to allow the parameter’s value to be stored and edited per snapshot. 1. Within the Signal Flow window, select the block which includes the parameter you wish to control via snapshots. For this example, we’ll choose the Litigator Amp+Cab block so we can control the amp’s Drive parameter. 2. In the Edit tab, right-click on the Amp’s Drive parameter and choose the Snapshots option. Assigning the Drive parameter to the Snapshots controller 3. You’ll see the parameter’s value appear in white and in brackets to indicate the Snapshots controller assignment. ----------------------------- After assigning the parameters to Snapshots, SAVE the preset. In each Snapshot, save the parameter values as you like, then SAVE the preset. SAVE the preset on the Snapshot you wish to be invoked when the preset first loads. Quote Link to comment Share on other sites More sharing options...
claudeu Posted August 25, 2024 Author Share Posted August 25, 2024 Thanks! You recommended: "After assigning the parameters to Snapshots, SAVE the preset." But how! Where is the SAVE button? Quote Link to comment Share on other sites More sharing options...
claudeu Posted August 25, 2024 Author Share Posted August 25, 2024 Do I have to take "Save to library"? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 25, 2024 Share Posted August 25, 2024 On 8/25/2024 at 6:25 AM, claudeu said: Do I have to take "Save to library"? Yes. Also, you don't need to SAVE between each change. Changes are retained (not SAVED) until you change presets. Saving to your LIBRARY makes the changes permanent. Quote Link to comment Share on other sites More sharing options...
claudeu Posted August 25, 2024 Author Share Posted August 25, 2024 Thanks from Berlin to Colorado! Quote Link to comment Share on other sites More sharing options...
