Drybonz Posted August 30, 2024 Share Posted August 30, 2024 I'm often getting loud pops when switching presets. Anyone else get this problem and have a fix for it? I don't want to have this sound when I'm playing with other people. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 30, 2024 Share Posted August 30, 2024 That’s sometimes the result of a large difference in the volume levels of the two presets, or a gain staging issue within a preset. First try leveling your preset volumes. Then try using the built-in Noise Gate in the Input block. 1 Quote Link to comment Share on other sites More sharing options...
razorwit Posted August 30, 2024 Share Posted August 30, 2024 Hi Drybonz, I've had pops occur when specific effects are enabled. If I recall correctly, the Kinky Boost is problematic. Have a look at your presets and see if there is a common pedal enabled in the ones that pop. Dean 1 Quote Link to comment Share on other sites More sharing options...
Drybonz Posted September 17, 2024 Author Share Posted September 17, 2024 Sorry for the delay, and thanks for the replies. This gives me something to go on. I found that I can copy a preset and get the pop going back and forth between the same preset, so it isn't a volume difference issue. I'm looking into how to correct any gain staging issues I might have. Also, not using Kinky Boost for anything, but I will keep an eye out for any pedals that might be an issue. Thanks again for the help. Quote Link to comment Share on other sites More sharing options...
theElevators Posted September 17, 2024 Share Posted September 17, 2024 Use the same amp. Don't change the impedance between presets. Don't have a compressor with severely aggressive settings on either presets. Quote Link to comment Share on other sites More sharing options...
