Power on MIDI OUT port?
catalano
On 11/15/2024 at 8:25 PM, catalano said:
Does anyone know if the Helix floor will output power (+3Vdc or +5vDC) on the MIDI OUT port? I'm looking to use a Bluetooth MIDI interface that gets its power from the MIDI OUT of a device.
You might want to take a look at using a WIDI device for wireless MIDI connections. See this post from @PierM who is a something of a wizard with this sort of stuff.
Hope this helps/makes sense.
On 11/15/2024 at 6:04 PM, datacommando said:
The WIDI is exactly what I was looking at. It draws its power from the MIDI Out port of whatever it is connected to. That’s why I was asking if the Helix floor had power at that port. The reply above yours said it couldn’t power anything, but I see in the pedalboard post you referenced that he has it plugged into a Helix Stomp.  So I’d have to assume that the floor could support it as well. Thanks.
Let me backpaddle a little from my statement "You can't power stuff over Helix's MIDI Out":
A standard MIDI Out was never intended to power devices, but it is build to power an optocoupler. The max constant current you can get from a standard MIDI OUT socket (like all Helix devices) is 5 V / (2 * 220 Ohm) =~ 10 mA. This means 50 mW of power at best.
However that is enough to power devices that need very little power like the CME WIDI Master.
Thanks. I just ordered one. I’ll post back once I test it.
Widi Master and Widi Jack are fully compatible with any HX device. Widi Master will take power directly from the Midi Out port.
UHost doesnt work due a code wall in the firmware. CME asked L6 to fix the issue, but it will never happen.
