Jack_Simmons2037 Posted November 19, 2024 Share Posted November 19, 2024 Hey y'all! So I'm a young aspiring guitarist and I'm looking to completely revamp my pedal board with an HX Effects, Slash MXR Octave Fuzz, Dunlop Volume X Mini, and a few other pedals I already have. Ive been looking for info on how to hook up the HX Effects and haven't found much answering my question Can I just run my HX Effects through the system like a normal pedal? my train of thought was Tuner-> Dunlop volume-> MXR Octave Fuzz-> HX Effects-> Hall of fame reverb-> Maybe a Boss Digital delay-> out to amp. now my question is can I use the HX Effects as a normal pedal (Having it go in a normal signal chain and just having flow through the pedals and not to the amp and back) or do I have to do the 4 cable method where I run the guitar through my normal pedals then to the amp then to the HX Effects and back to the amp? Much help would be appreciated! -Jack! Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 19, 2024 Share Posted November 19, 2024 It’s up to you. You can just place it in-line with your other pedals as you’ve shown or you can use the 4CM assuming your amp has an FX loop. The advantage of the 4CM is that you can place HX FX blocks and your physical pedals (e.g. reverb, delay) after your preamp in the signal chain. Some people prefer to place time based FX after the preamp and before the cab/speaker; 4CM lets you do that. 2 Quote Link to comment Share on other sites More sharing options...
Schmalle Posted November 19, 2024 Share Posted November 19, 2024 What @silverhead said. Btw you can use your Dunlop pedal as expression pedal and control parameters of effects on the fly ( see the DVP4's manual). Common examples are volume, wah, delay time, modulation etc. Quote Link to comment Share on other sites More sharing options...
Jack_Simmons2037 Posted November 19, 2024 Author Share Posted November 19, 2024 Thank yall so much! i’m glad i can just keep it as a pedal because my amp doesn’t have the 4CM with it… i’ll let yall know how it goes! Quote Link to comment Share on other sites More sharing options...
