ledvedder5150 Posted December 6 Share Posted December 6 Can someone please explain how I can change path B output to send1/2, like this guy did in this video? For the life of me, I can't figure it out. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted December 6 Share Posted December 6 See the manual p. 38: Setting Path B’s Output There may be situations where you want parallel Path B to be sent to a completely different set of outputs. 1. In the Signal Flow view, turn the Big Knob to select the point where the two paths merge. The Mixer block appears only when selected: 2. Touch Footswitch 2 and turn Knob 2 (Path B Output) to select “Send12.” The Mixer block splits into two, indicating Path A is being sent from the HX Effects hardware’s Main L/R outputs and Path B is being sent from its Send 1/2 outputs. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted December 6 Share Posted December 6 I don't have an HXS, but it looks like all he did was put in an IR Block, pulled it down to create PATH B, then he pulled down the MIX Block to complete the split, but the rest makes sense - PAN PATH A full LEFT/1 which completes the 4cm and pan the PATH B/2 full right to prevent FB. In his video he left out the "pulled down the MIX Block to complete the split". Is the HXFX not allowing you to pull down the MIX Block? Quote Link to comment Share on other sites More sharing options...
