ltwhite Posted January 15 Share Posted January 15 Hi all, I just recently picked up a Voodoo Labs Ground Control Pro and I was curious if there's a way to change the set 4 Preset buttons on the GCP (which goes right to the Bank# A, B, C, D presets like it should) to be controlling Snapshots #1-4 instead of the Presets. Currently I've got the 8 Instant Access buttons to control the 6 button Looper functions, Tap tempo, and a Tuner toggle as my Tap/Tuning button really doesn't work too well. Does anyone know if possible to change the CC numbers internally or define them on the Helix so that I could do this? Or does anyone have experience with the GCP and changing the Preset 1-4 values? Would this be possible with SysEx editing maybe? Since we're here, anyone have any suggestions for cleaning the Helix footswitches without completely disassembling the Helix? Would be great to have 2 more instant access buttons on the GCP I could assign if I could get my Tap/Tuner button working reliably again :( Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 15 Share Posted January 15 Check the MIDI section of the Helix manual. I believe the correct CC #s to recall snapshots are listed there. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted January 16 Share Posted January 16 On 1/15/2025 at 5:17 PM, ltwhite said: Does anyone know if possible to change the CC numbers internally or define them on the Helix so that I could do this? Yes, it is in the Helix v3.80 Owner’s Manual on Pages 77-78 in the MIDI section. https://line6.com/data/6/0a00051afda2673ccc1cc8e68/application/pdf/Helix 3.80 Owner's Manual - English .pdf Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
ltwhite Posted January 16 Author Share Posted January 16 Thanks for the replies guys. Unfortunately finding the CC#s on the Helix is not the issue I am having :( I've been programming with the Unofficial Helix MIDI guide so everything has been going great until I get to these 4 Preset buttons on the VL GCP. I'll hit up the Voodoo Labs forums and see if there's a way to reprogram the #1-4 Preset buttons, but everything I have looked at and read online leans towards no :/ I'm also using the GCP a bit unconventionally, the #1-4 Preset buttons are "supposed to" be used with having different presets of the 8 Instant Access buttons right above the #1-4 Preset, like the Snapshot functionality on the Helix. However, I'm trying to have dedicated looper controls on the GCP and use those #1-4 Preset buttons at the bottom to control Snapshots #1-4 on the Helix instead of cycling through the ABCD set of preset 4s in each Setlist on the Helix. I don't really utilize the presets yet because I typically have been using the Helix as a multieffects > my amp, but I've been leaning a lot more towards using the amps + cabs on the Helix these days so I may just end up trying to take advantage of having the 10 Helix buttons + 4 Preset + the 6 Looper + Tap/Tuner controls right at my feet at all times. Quote Link to comment Share on other sites More sharing options...
enjalt Posted January 28 Share Posted January 28 I don't know if the tap/tuner switch is editable , but via the command center I think you can make want you want to. You can select a switch and program it like a Midi Controler. Check the command center section on the manual Quote Link to comment Share on other sites More sharing options...
